2 white wires in SI dizzy harness ?
i've read all about them..
i know one is an o2 senser..
if they're switched, will it keep the engine from starting ?
Modified by terminaloverlowd at 1:59 PM 6/19/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terminaloverlowd »</TD></TR><TR><TD CLASS="quote">i've read all about them..
if they're switched, will it keep the engine from starting ?</TD></TR></TABLE>
yep if the car wont start i might be you have them mixed up
i'll give that a try..
i switched them twice last night trying to get it to fire up, but in retrospect, there's also a good chance i flooded it last night..
i didn't know how long the engine had been sitting, so i took out the plugs and shot a quick spray of wd40 in each cyl, for a couple quick cranks without the plugs.. to give the rings a little lube..
after i did, i realized i was still firing gas, so there's a chance it was just flooded last night..
i'll switch the 2 whites again and see what happens..
Caylen Klassen
Jan 21, 2016 06:15 AM
