i Just bought a d16y8 ... i want to put it in myself.. Need alot of INFO
mostly i can imagine ...... but it all about the winring... i guess im goiing 0bd1.. so will i need that wire harness ? .. i still have my obd0 harness. but i dont think it plug into the ecu obd1... i would like to know in detail what wire are going to have more.. and.. evrything you can imagine in the wiring to put it obd1.. thx
are the mount positions the same on the two blocks? if so just install it as if you are doing a mini me build
there's tons of info on here just search it's a great way to learn
Use your stock mounts, and replace the Y8 timing belt mount's bracket with your stock one, and grind some off so it doesn't rub the timing belt.
yes i looked and there;s info... but nothing saying from 0bd0 to 0bd1 ...... it;s what i need to know! .... what will i NEED... distrubutor ??? odb2 good ??? what else could i need ??
d_boi_swag
May 12, 2009 04:08 PM
Budget Racer
Sep 12, 2007 12:12 PM
