removing piston from caliper
Old Jun 19, 2004 | 02:10 AM
david90's Avatar
Default removing piston from caliper
Manual saids to use compress air to blow out the piston but what if you don't have access to compress air? Is there another way remove the piston with using compress air?
Old Jun 19, 2004 | 02:32 PM
IN VTEC's Avatar
Default Re: removing piston from caliper (david90)
Push the brake pedal down slowly.
Old Jun 19, 2004 | 03:28 PM
david90's Avatar
Default Re: removing piston from caliper (IN VTEC)
wouldn't that result in an explosion of brake fluid? I'm talking about when the caliper is removed from the brake system and is on my desk.
Old Jun 28, 2004 | 09:30 PM
mist sITR's Avatar
bike pump will probably be good enough as ling as u can get a good air tight seal
Old Jun 28, 2004 | 10:10 PM
murtnabila's Avatar
Default Re: removing piston from caliper (mist sITR)
open bleed valve and pull it out with a pair of pliers or something. I did it by hand, it was tough, but came out.
Old Jun 29, 2004 | 07:24 AM
Wes V's Avatar
Default Re: removing piston from caliper (murtnabila)
FIRST OFF; This can be done safely, but you have to be careful!!!
Get a length of 2x4 wood that you can position in the middle of the caliper (where the rotor would go) with the pads removed. Use a piece of rubber with a hole in it that can be used as a seal. Then go to any gas station and use their air line to pressurize the caliper and blow out the piston.
And the correct wording for this is "blowing" out the piston! It will come out suddenly and if the 2x4 isn't there, it could jump clear out of the caliper assembly. If your fingers are in the way, they will be crushed.
You only have to do this once to see why I'm giving all the cautions. Just be throughtfull and carefull.
Wes
Old Jun 29, 2004 | 07:40 AM
PnX-R's Avatar
Default Re: removing piston from caliper (Wes V)
I'm glad somebody told these guys how to properly do it..
Old Jun 29, 2004 | 11:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Push the brake pedal down slowly.</TD></TR></TABLE>Yeah, the brake pedal is probably closer than your nearest gas station. All these ideas will work, just pick one & do it. If the brake hose is still connected, pumping the pedal is probably easiest. YES it'll spill brake fluid all over, but all you have to do is catch it in a pan... Just be careful, if you have any other calipers off, they'll push their pistons out, too.
Old Jun 29, 2004 | 01:20 PM
Wes V's Avatar
Default Re: removing piston from caliper (JimBlake)
Although using the brake pedal would work, it just dawned on me that you could only do one caliper! At that point, all the fluid would just come out the caliper that has it's piston already removed.
As for not having access to an air compressor, just about any gas station has one for adding air to the tires. However some gas stations may not want you doing it due to their being conserned that you could hurt your self.
Just find one of the stations that have one of the pumps that need quarters and do it before they know what you are doing.
Wes
Old Jun 30, 2004 | 03:36 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V &raquo;</TD></TR><TR><TD CLASS="quote">Although using the brake pedal would work, it just dawned on me that you could only do one caliper! At that point, all the fluid would just come out the caliper that has it's piston already removed.</TD></TR></TABLE>Oh yeah, that's true! I suppose you could finish the caliper before dismantling the next one. I really don't remember it being that hard to take the piston out. I probably grabbed it with a pliers or something.
Old Jun 30, 2004 | 04:05 PM
david90's Avatar
plug up the line? I never realize how dangerous it is.
Old Jul 7, 2004 | 10:47 PM
DC2 to AP2's Avatar
Default Re: (david90)
i just did this to all my calipers. unbolt the brake line, take a punch that fits the hole and push it out slowly. it works and the pistons came out perfectly.
antoine78
Jul 8, 2011 10:00 AM
rdssk8rcs1
10
Apr 11, 2008 04:54 PM
Web_Head
Jun 23, 2004 12:26 PM
More&Faster
Dec 18, 2003 03:52 AM
Timmy!
May 1, 2003 12:38 PM
