what does the timing banlancer do?
Old Jun 19, 2004 | 12:54 AM
david90's Avatar
Default what does the timing banlancer do?
what is the purpose of timing banlancer?
Why is it necessary to stick a bolt into the mantenance hole when installing the belt?
Old Jun 19, 2004 | 02:02 PM
GZERO's Avatar
Default Re: what does the timing banlancer do? (david90)
hmmm...not sure what that means, are you talking about the balancer on your timming belt? if soo, you're talking about a 2lt or bigger engine, right?
Old Jun 19, 2004 | 03:31 PM
david90's Avatar
Default Re: what does the timing banlancer do? (GZERO)
yes. What is that system for?
Old Jun 19, 2004 | 05:54 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">yes. What is that system for?</TD></TR></TABLE>
It reduces vibration. The balancer shafts need to be properly timed to work right.
Old Jun 19, 2004 | 08:09 PM
GZERO's Avatar
it spins at either twice the speed of the crank or half the speed of the crank (i can't remember), but it cancels the vibrations made from the crank, it makes the engine more smooth and it's only used on engines that are 2lt or more...
Old Jun 20, 2004 | 12:03 AM
civickiller's Avatar
dont they also block off the oil passage maintaining oil pressure in the engine, like if you took the shafts out then you wouldnt have oil pressure. or at least thats what i read in a magazine in a rage article
Old Jun 20, 2004 | 04:05 PM
GZERO's Avatar
Default Re: what does the timing banlancer do? (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">dont they also block off the oil passage maintaining oil pressure in the engine, like if you took the shafts out then you wouldnt have oil pressure. or at least thats what i read in a magazine in a rage article</TD></TR></TABLE>
well, they are just like the bearings on the engines, they need oil pressure, if you take the shaft out that will leave everything open and you won't get pressure at all since you're loosing it right there.
Old Jun 22, 2004 | 10:33 PM
david90's Avatar
so I do something to balancer when doing timing belt?
Old Jun 23, 2004 | 08:32 AM
GZERO's Avatar
Default Re: (david90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">so I do something to balancer when doing timing belt?</TD></TR></TABLE>
huh? i don't get it, when you're doing the timming belt you have to align the balancer with the mark
Old Jun 23, 2004 | 01:12 PM
david90's Avatar
Default Re: (GZERO)
ops. What I meant to say was should I do some kinda of mantenance work on the balancer when doing tbelt.
Old Jun 23, 2004 | 01:44 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david90 &raquo;</TD></TR><TR><TD CLASS="quote">ops. What I meant to say was should I do some kinda of mantenance work on the balancer when doing tbelt.</TD></TR></TABLE>
You might want to install a balancer seal retainer if it doesn't already have one.
Old Jun 25, 2004 | 07:06 AM
PnX-R's Avatar
You're talking about Preludes and Accords huh?.. I don't even use a screw. I just use whatever is lying around and will fit through the opening. I shove it in there and take a rough measure and bolt it back together.. I've never had a problem.. Have fun..
Old Jun 25, 2004 | 10:45 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">it spins at either twice the speed of the crank or half the speed of the crank (i can't remember), but it cancels the vibrations made from the crank, it makes the engine more smooth and it's only used on engines that are 2lt or more...</TD></TR></TABLE>
So does this mean that they are on B20s and not B18s? Or can you get one for a B20. Um, yea, If you can't tell, I'm going B20.
Old Jun 25, 2004 | 11:46 AM
GZERO's Avatar
Default Re: (MugenDude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">
So does this mean that they are on B20s and not B18s? Or can you get one for a B20. Um, yea, If you can't tell, I'm going B20. </TD></TR></TABLE>
don't quote me, but i think the B20 doesn't have it, is not a rule, is more like a rule of thumb, either way some car have them and some don't....
Old Jun 26, 2004 | 08:34 AM
hmm, i wonder what kind of differences would i see if i put one on a b20...
Old Jun 26, 2004 | 09:07 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude &raquo;</TD></TR><TR><TD CLASS="quote">hmm, i wonder what kind of differences would i see if i put one on a b20...</TD></TR></TABLE>
LOL
Old Jun 27, 2004 | 01:28 PM
GZERO's Avatar
you'll loose a lil power and get in return a smoother engine, but is not something you can add, add least not easily, they are built in the block
Old Jun 27, 2004 | 02:24 PM
david90's Avatar
what is the purpose of putting a bolt thru the balancer when servicing it? Why do you need to do it?
Old Jun 27, 2004 | 02:27 PM
GZERO's Avatar
so the pulley doesn't moves around, it's just there to make the work easier/faster, remember that you have to align the balancer shaft pulley with a mark on the block
mrau92me
Jun 3, 2018 10:37 AM
CNSK
Dec 8, 2005 02:12 PM
KL14
Nov 7, 2005 09:11 AM
VTgringo
Aug 11, 2004 03:47 PM
D15B7
Acura TL, RL & ZDX
Aug 22, 2002 07:40 PM
