Some more BSQ rear swaybar installation questions
Old Jun 18, 2004 | 09:55 PM
beanbag's Avatar
Default Some more BSQ rear swaybar installation questions
It looks like the swaybar bushing is a little too big for the bracket, i.e. the bushing sticks out a little bit. If I crank down on the mounting bolts to the required torque, will the ends of the bracket actually touch the steel plate, or should I wedge washers in between?
It also looks like the 1/2 inch spacer is a little too short, in that the steel plate doesn't quite clear the ABS bracket. Should I also put a washer in there to make the spacer taller, or maybe trim the corner of the plate down so that it can fit in the indentation of the abs bracket? (I made the kit myself according to the specs on his site)
The bottom mounting hole basically has the ABS bracket pressing into the cross-member. It look like the area it presses down on is only a little larger than 5/8" diameter. What about putting a washer underneath that?
Old Jun 19, 2004 | 03:28 AM
IntEGNYC's Avatar
Default Re: Some more BSQ rear swaybar installation questions (beanbag)
you couldnt afford the $20 for the kit?
the bsq kit is all you need.
Old Jun 19, 2004 | 09:20 AM
beanbag's Avatar
Default Re: Some more BSQ rear swaybar installation questions (IntEGNYC)
REAL MEN make their own BSQ kits, on mills and lathes.
wite2nr
Suspension & Brakes
20
Dec 8, 2009 11:52 PM
All-Motor-Junkie
Jan 14, 2007 04:05 PM
Coupe-R
Aug 31, 2006 04:56 PM
GSRrR
Jun 28, 2003 10:26 PM
