Need HELP! are these the right spark plugs?
my friend got me some denso spark plugs, he said he asked for spark plugs that woudl fit in a 1994 del sol si at autozone. they are denso KJ16CR-L11 is that the correct one and will it work for my b16a? need to know before i put them in. and im guessing the gap for my b16a is .044in right? thanks
are there any other numbers on there?? Are they regular or platinum? Autozone uses the 4 digit numbers for their part numbers. You should have looked up a '97 Del sol w/ DOHC vtec. They are 2 different part numbers.
whats the other digits on the box. Not the one you gave. The listing that I am getting is 3142 and that is the Denso platinum, no reg are recommended for the B16 in Denso.
I work at Advance Auto part-time and the listing that I am getting from them is NGK platinums 3141 (pfr6l-13)
Nopi shows the same also. The denso plat. 3142 or the NGK plat. 3141. You may have the wrong plugs.
why get platnium plugs?????
werd
for all motor regular plugs are the best
I used the new
ngk iriudioum(spell check)
and they did nothing different
verus my regular ngk plugs
in my ls/vtec set up.....
werd
I used the new
ok the only thing it says is KJ16cr-l11#4 and part number 3132#4. on the corner it reads D35. i looked it up at autozone.com and they have these for both the 94 del sol si and 2000 civic si.
Do those number actually make a difference? I just grabbed 4 packs of NGK iridiums and all I knew what that I was looking for the number 7 in the middle because Im spraying, didnt think it matterred
R.R
Nov 24, 2010 07:03 AM
red civic standard
12
Mar 21, 2002 05:38 PM
