cams w/turbo h23???
Old Jun 18, 2004 | 07:33 PM
sgrrrr's Avatar
Default cams w/turbo h23???
Is ir really neccesary to get some crower turbo grind cams for my turbo h23? Im building the block and all and cant send it to the machine shop til i know if i want cams or not. How many of you out there with a turbo h23 are making big power without aftermarket cams? Will i notice THAT much of a difference with turbo cams? or is it a waste of money? any input is welcome... thanks
Old Jun 18, 2004 | 10:48 PM
flip1199's Avatar
Default Re: cams w/turbo h23??? (sgrrrr)
i dont think anyone is running the crower turbo cams on there h23 here yet.
Old Jun 19, 2004 | 04:16 AM
spoolinlude's Avatar
I live under a rock
Default Re: cams w/turbo h23??? (flip1199)
screw cams........ just crank off more boost
Old Jun 19, 2004 | 08:32 PM
sgrrrr's Avatar
Default Re: cams w/turbo h23??? (spoolinlude)
so the stock cams will be more then adequate? youre using stock cams spoolin? cus i know your h23 set up kicks ***.....
Old Jun 19, 2004 | 08:33 PM
Kal's Avatar
Kal
turbo cams just have more overlap, stock cams will do you fine.
Old Jun 20, 2004 | 06:11 AM
sgrrrr's Avatar
Default Re: cams w/turbo h23??? (Kal)
one more question.... how many of you pushing high boost are running on stock valves? if you arent on stock valves where did you find aftermarket ones for the H23?? thanks
Old Jun 20, 2004 | 06:40 AM
I live under a rock
yup stock cams..... i got this local machine shop to actually make my valves, but stock ones are fine
Old Jun 21, 2004 | 01:01 PM
sgrrrr's Avatar
i know i just keep going with the questions.. pauter or crower rods??? thanks
Old Jun 21, 2004 | 01:15 PM
93ludeSi's Avatar
crowers are gonna be a little cheaper... usually... but they both make an excellent rod.... i run crowers in my all motor h23
thresher
Nov 27, 2008 09:14 PM
BokChoy
Apr 1, 2006 07:52 AM
95ATEG
Oct 2, 2004 07:57 PM
prelude beast
Jun 10, 2003 11:52 AM
BoostedH23a1
Sep 20, 2002 05:53 AM
