swap done.. engine wont turn over.. couple quick questions..
Old Jun 18, 2004 | 07:30 PM
terminaloverlowd's Avatar
Default swap done.. engine wont turn over.. couple quick questions..
swaps done, engines in..
i've got gas, spark, and compression.. engine sounds like it's trying so so so hard, but it just wont fire..
i'm unsure about the small vac line connections to the throttle body.. one is on the back of the intake manifold and the other is on the throttle body.. not sure which goes to which one..
but it should still turn over, right ??
any ideas, things to check, things to double check ?
thanks
Old Jun 18, 2004 | 08:52 PM
91civicDXdude's Avatar
double and triple check your ground connections. 99.9999% of the time its a loose ground.
As for vacuumlines, honestly, it doesnt matter where you hook them to, as long as they have vacuum. you can run every vacuum line off one one port with a bunch of T's on it if you wanted to.
Old Jun 18, 2004 | 08:57 PM
Default Re: (91civicDXdude)
example ?
you mean like the ground between the resistor box and where it's mounted ?
Old Jun 19, 2004 | 05:34 AM
drussell4801's Avatar
Default Re: (terminaloverlowd)
if your engine is the issue, double check your engine grounds.
rizaldepan
May 26, 2019 04:46 PM
mfreeman
10
Nov 1, 2013 08:34 PM
bbLUDE
Mar 22, 2008 09:46 AM
