fs: skunk2 intake manifold for b16/b18c5 and itr red valve cover, hasport motor mounts
Old Jun 18, 2004 | 06:56 PM
b16powwer's Avatar
Default fs: skunk2 intake manifold for b16/b18c5 and itr red valve cover, hasport motor mounts
make offers, if you dont like the price.
96 gsr stock uncut wiring harness $100.
obd-2 dizzy, under 3k miles $150.
96 gsr alternator w/aem pulley and belt $100.
96 gsr starter $50.
96 gsr (would like to sell as a set)
axles, motor mounts, shift linkage, inter shaft,
every bolt, bushing and short shifter. $325.
4-14" tires $75.
(tires are like new, less then 5k miles on them)
tire size 175/65/14
88-91 crx/civic hasport motor mounts $260.
billet ones, b'series motor swap
clutch net clutch, for b16a1 cable trannys, under 3k
miles on it. paid $380. for it. asking $175.
will work on 90-91 integra b' series trannys
itr usdm header w/gasket $50.
skunk2 intake manifold w/eaic
for b16/b18c5 heads $175.
ported to match 70mm throttle body
msd 6a box, ss blaster coil,
obd-0 dizzy w/cap and wire $275.
88-91 civic/crx stock muffler $5.
(just muffler, will work on EF'S)
2.5" glasspack 18" long $5.
91 crx si throttle body w/no sensors $5.
91 crx si stock cat $5.
91 crx si stock rotors
(all 4 corners in great shape) $25.
91 crx si stock brake lines (all 4 lines) $15.
91 stock crx si intake box w/filter and tube $15.
92 civic vx stock box w/filter and tube. free w/anything you buy, pick up only
91 crx dx stock steering wheel $5.
97 gsr stock flywheel $15.
96 gsr stock flywheel $15.
obd-2 injectors from a 97 gsr (all 4) $20.
obd-2 injectors from a 96 gsr (all 4) $20.
b16a1 stock fuel regulater $10.
91 crx si stock header $10.
91 crx si shifter $5.
91 crx si stock springs all 4 $20.
91 crx si stock sturts (all 4 in great shape) $25.
97 gsr stock head studs 1.8L (all 10 studs) $20.
91 crx si stock shifter $5.
Modified by b16powwer at 11:10 PM 7/23/2004
Old Jun 19, 2004 | 08:34 PM
Blitzed's Avatar
Default Re: fs: skunk2 intake manifold for b16/b18c5 and itr red valve cover, hasport motor mounts (b16powwe
Have any pics of your parts man?
Old Jun 19, 2004 | 09:16 PM
b16powwer's Avatar
will have pics sunday nite. thanks
Old Jun 19, 2004 | 11:12 PM
Wesb18DB8's Avatar
i'm interested in ur Valve cover, what kind of condition is it in? thanks
Old Jun 20, 2004 | 09:53 AM
b16powwer's Avatar
SKUNK2 INTAKE MANIFOLD (B16/B17/B18C5) HEADS
ITR VALVE COVER (CUT FOR CAM GEARS)
88-91 CIVIC/CRX HASPORT MOTOR MOUNTS LESS THEN 2K MILES ON THE TRANNY MOUNT, OTHER 2 MOUNTS ARE STILL NEW THE WRAPPERS.
Modified by b16powwer at 7:48 PM 7/1/2004
Old Jun 20, 2004 | 10:01 AM
jaydmcrx's Avatar
Ill vouch for this guy. He is super nice guy, and got me my parts right away. Even he was suprised at how fast i got them. haha. Buy his ****. its barely used!!!!!
Old Jun 20, 2004 | 10:04 AM
b16powwer's Avatar
Default Re: (jaydmcrx)
thanks alot sean
Old Jul 4, 2004 | 05:53 PM
b16powwer's Avatar
more pics of the skunk2 intake manifold
b16powwer
Aug 3, 2004 09:45 PM
b16powwer
Jun 27, 2004 08:09 AM
b16powwer
Aug 14, 2002 09:29 PM
