Review of my compression test results
Old Jun 18, 2004 | 04:46 PM
kurinto's Avatar
Default Review of my compression test results
I compression tested the 98 LS I have the ghetto way - hooking up flywheel, trans, starter and jumping it. I got around 175 all the way across except for one of around 160-165. We put some oil in that cylinder and got like 185, let it sit for a bit then did it again and got 175. Is that variance a big concern?
My dad thought that maybe we weren't getting the comp. tester tightened consistently so we rigged up a pipe to replace the hose and got like 175 all across.
I guess just the fact that the one cylinder jumped when we put oil in it is my concern but is it enough to take the engine back and have to find another one?
Old Jun 18, 2004 | 04:53 PM
Lord Helmet's Avatar
Default Re: Review of my compression test results (kurinto)
15 psi is acceptable range for all cylinders. you would be in the recommended factory specs.
hence 160-175 psi is ok.
Uncle Ben's
Dec 8, 2007 12:21 PM
John.
Jun 12, 2006 08:45 AM
jeison
May 13, 2006 05:00 PM
VTC_CiViC
Oct 8, 2001 06:11 PM
wantmorepower
Aug 17, 2001 02:55 PM
