Changing engine oil and found no oil going through the oil filter...
Old Jun 18, 2004 | 01:03 PM
CW-ITR's Avatar
Default Changing engine oil and found no oil going through the oil filter...
Anybody ran into this problem? Changing engine oil and found no oil going through the oil filter. I then eliminated the oil cooler set up by taking out the sandwich adapter. Put the same oil filter back. Put fresh oil in and drive the car for 30 miles. Took the oil filter back out and still no oil circulate through the oil filter (the inside is dry)??? No engine lights come on one-so-ever, no hesitation and V-tec kicked in like normal??? I don't understand.
Chris
Old Jun 18, 2004 | 02:04 PM
Stewie's Avatar
Default Re: Changing engine oil and found no oil going through the oil filter... (CW-ITR)
Maybe you just have a bad filter. Could be a sticking bypass valve.
Old Jun 18, 2004 | 02:19 PM
1GreyTeg's Avatar
Default Re: Changing engine oil and found no oil going through the oil filter... (Family Guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Family Guy &raquo;</TD></TR><TR><TD CLASS="quote">Maybe you just have a bad filter. Could be a sticking bypass valve.</TD></TR></TABLE>
Good call
What type of filter/brand is it again?
Get a new filter and try it again.
Old Jun 18, 2004 | 02:44 PM
SC94DB8's Avatar
Default Re: Changing engine oil and found no oil going through the oil filter... (1GreyTeg)
I had the same thing happen to me with a Fram filter.
My guess was that the bypass valve stuck also.
I still use them and havn't seen it happen again.
Old Jun 18, 2004 | 03:57 PM
CW-ITR's Avatar
It was an OEM filter. I replaced with another OEM filter this morning. I'll check it when I get home today. How do you check for sticking bypass valve? Thanks for all the help suggestions.
holmesnmanny
Dec 10, 2009 03:14 AM
happynoodleboy
Feb 20, 2008 06:34 PM
skunk2finatic
Oct 28, 2004 10:05 PM
TeGGY_LS
Aug 6, 2004 01:16 PM
GGSSRR
Sep 6, 2001 09:10 PM
