Whats the max PSI on the SC34 and the SC61
Old Jun 18, 2004 | 12:22 PM
Rocks
Guest
Posts: n/a
Default Whats the max PSI on the SC34 and the SC61
Im in the market for an upgrade on my current kit. I was just wondering whats the max PSI on both of these turbos . Thank YOU. I tried searching but was dumbfounded.
Old Jun 18, 2004 | 12:34 PM
PrecisionH23a's Avatar
Default Re: Whats the max PSI on the SC34 and the SC61 (SiRocks)
It depends on which trims you go with. Obviously the larger the a/r trims the more boost it can run while not running out of its efficiency range.
Example
My t04e sc61 60comp .58 a/r t4 p-trim will be good for around 30psi or so I believe.
Old Jun 18, 2004 | 01:12 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Whats the max PSI on the SC34 and the SC61 (PrecisionH23a)
I have never seen anyone max out the boost on an SC61 or SC34, so its on up there
Old Jun 18, 2004 | 01:17 PM
CRX T-Si's Avatar
Why does the Max PSI matter on your upgrade??? Are you making that much HP to worry about this??
You can always look at the Precision specifications for the HP rating so that will give you a better idea on HP then you worrying about the MAX PSI.
http://www.precisionte.com/sportcompact.php
This should help in your search.
Old Jun 18, 2004 | 01:24 PM
Rocks
Guest
Posts: n/a
Default Re: Whats the max PSI on the SC34 and the SC61 (CRX T-Si)
The max psi dosent really matter in my upgrade since the most PSI I will be running is problably 12-14 PSI. I just wanted to know how much psi are these Turbos capable off because I will be getting a SRT4 in the future and I plan to take it off my civic and put on my SRT4.
Old Jun 18, 2004 | 01:46 PM
RyanEJ8's Avatar
The SC61 could run 30+psi. You should be concerned with your whp goals though, not the psi.
Old Jun 18, 2004 | 02:15 PM
DD_JonnyLee's Avatar
Default Re: Whats the max PSI on the SC34 and the SC61 (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">The SC61 could run 30+psi. You should be concerned with your whp goals though, not the psi.</TD></TR></TABLE>
well put
model x
Sep 8, 2003 01:05 AM
fastlude69
May 13, 2003 07:30 AM
TurboSedan
Apr 22, 2002 08:37 PM
