Who has made 210+ WHP with OEM H pistons? Post your set ups here...
I got into a conversation recently with a good friend of mine whos been building honda road race and drag race motors for several years... He claims that OEM H series pistons crumble with little over 200WHP and or 12.5:1 compression due to the weak ring lands and by his account he has personally seen it happen at least 10 times over the last 4 years...
He also told me that hes shrinking the chambers down in some of these motors to get compression ratios into the 13's... Hmmm...
On the other hand, I know there are quite a few guys putting down 200+ that have had no issues what so ever with their OEM pistons...
Id like to see just who on H-T has reached the 200+ mark on OEM pistons, what your set ups are and track them for the next few months to see if this is something that happens to both street and race motors or just to track queens pushing the limits...
Post away...
Post away...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn »</TD></TR><TR><TD CLASS="quote">You can get there with stock pistons, but you wont last long with stock pistons.</TD></TR></TABLE>
eh, I disagree... Thats why I wanted to start this thread up to get more info on this subject and maybe track a few set ups for a while...
Um, plenty of people with well tuned JRSC H22 setups with stock bottom ends pushing 230+ whp with no issues. I put down about 190 whp on mine with my auto tranny, would have been about 210 whp with a manual. Still running strong, even pushed 9 psi for over a year.
you should be able to hold 200 - 250 just fine on stock pistons. when you start boosting crazy numbers is when ringlands go. i havent heard anyone with all motor having a problem with bad ringlands. i could be wrong, wouldent be the first time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lildrgn »</TD></TR><TR><TD CLASS="quote">I know plenty of people too making above 200 with stock pistons. But I also know more people who have destroyed their engines after extended use. </TD></TR></TABLE>
okay, if you remove Todd from that group would you be able to make the same statement?
Im personally running ctr's in my gsr with some other work done but what kind of work in perticular are you looking to watch for in the H? is it just something that makes 210 and up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 »</TD></TR><TR><TD CLASS="quote"> talk to fire drake.
h22a1, 60-1 t3 turbo.</TD></TR></TABLE>
Wurd, he's putting down close to 400 whp on a stock block
H23 VTEC all motor (no FI)
230/180 at the wheels
Lasted 5 minutes on the track before the ringlands falied.
OEM Type S pistons.
11.5/1 CR
OEM Type S pistons.
11.5/1 CR
Just did a compression test: 230 230 230 230. 2000 lude with JRSC, had it on for over 1.5 years and 13k miles, over half that at 9 psi. Stock bottom end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis »</TD></TR><TR><TD CLASS="quote">Is corey running stock internals (stock as in as it came not type-s..)</TD></TR></TABLE>
yes, STOCK .025 over pistons.. I'm over 210 now.. Raced all the time..
Here's a dyno of my h22civic, although it wasnt tuned properly it had a fuel leak I believe contributed to its demise shortly after, we cut it off after noticing the fuel leak, thats why it cuts off just before 6500, it obviously was on its way well over 300
the turbo was a to4e 57trim with .60A/R
97accordbuildlx
Jan 19, 2013 07:55 AM
jeremy.
17
Oct 21, 2004 10:34 PM
