Garrett T25 oil return fitting size and clocking issues! *frustrated*
Old Jun 18, 2004 | 09:12 AM
EJ1 wilcox's Avatar
Default Garrett T25 oil return fitting size and clocking issues! *frustrated*
:::See update at the bottom of this post:::
First of all, I can't figure out the stinkin oil return fitting size on my Garrett T25 turbo...
I don't want to have to buy a flange, then drill and tap holes for the bolts if the drain is already threaded!!
Does anyone know the size????
I have tried to contact Garrett but without any luck! They have no direct email address or phone number on their web site! (how ghetto is that?)
I then tried to email three different distributors whos email addresses I found on Garrett's site...but I had all those kicked back to me because the email addies were all bunk!!
I am also having issues clocking the stupid thing...I have some heavy duty snap ring pliers but they keep slipping off! I've been trying to get that snap ring off so I can clock the compressor housing and then tap new holes for the wastegate, but I can't get that stupid snap ring undone!!!
Thanks for any tips you might have...sorry if I'm frustrated...
:::Cliff notes:::
1. I need to know the oil return fitting size
2. I need some pointers on getting the huge snap ring free so I can clock the turbo...
:::Update:::
I finally figured out how to clock the darn thing! Now I just need to find a way to mount the wastegate...
****I just spent some time at STS turbo (http://www.ststurbo.com/home) because they are local here...
They carry a TON of turbo fittings because they do custom kits, but we couldn't figure out the size of the oil return fitting!!
If anyone knows the size of this fitting or another alternative to the oil drain I would really appreciate it!
BTW... a guy at STS has a remote mount turbo CRX (the turbo sits in the back where the muffler usually is)....sweet....
Modified by EJ1 wilcox at 3:34 PM 6/21/2004
Old Jun 18, 2004 | 09:19 AM
Blackack26's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (EJ1 wilcox)
hopefully Flamenco-T can chime in on this, he knows a thing or two about oil lines
Old Jun 18, 2004 | 09:20 AM
DaX's Avatar
DaX
Loved
Community Favorite
Maybe 1/4" NPT?
Are your snap ring pliers angled?
Old Jun 18, 2004 | 09:30 AM
EJ1 wilcox's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">hopefully Flamenco-T can chime in on this, he knows a thing or two about oil lines </TD></TR></TABLE>
I already asked him...he doesn't know...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Maybe 1/4" NPT?
Are your snap ring pliers angled?</TD></TR></TABLE>
Yes, they are angled but they keep slipping off anyways!
Old Jun 18, 2004 | 09:40 AM
Gravy's Avatar
it is an inverted flare. with a metric thread. xrp makes a powersteering fitting that will fit like a glove. and it comes out to a 4an flare. xrp part number 402704.
Old Jun 18, 2004 | 09:43 AM
Gravy's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (Gravy)
now that i look at the pic that looks like the inlet. not the drain. drain should have two bolts to put a flange.
Old Jun 18, 2004 | 09:47 AM
EJ1 wilcox's Avatar
Thanks for the replies!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">now that i look at the pic that looks like the inlet. not the drain. drain should have two bolts to put a flange.</TD></TR></TABLE>
I don't know why there are no threads for a flange...
Here's the oil inlet
I'm sure it's the drain...
Old Jun 18, 2004 | 09:48 AM
tgreaves's Avatar
Call htturbo.com.. I needed some gaskets for my turbo and they knew exactly what I needed and sent them to me.. They are very knowledgable..
Old Jun 18, 2004 | 09:54 AM
Gravy's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (tgreaves)
do you have a pic that nots so close?? its hard to tell the difference
Old Jun 18, 2004 | 10:10 AM
fsp31's Avatar
&gt;&gt;&gt;I am also having issues clocking the stupid thing...I have some heavy duty snap ring pliers but they keep slipping off! I've been trying to get that snap ring off so I can clock the compressor housing and then tap new holes for the wastegate, but I can't get that stupid snap ring undone!!!&lt;&lt;
It's been awhile since I clocked my T25, but I did not have to remove the snap ring to do it. Just remove the bolts and give the compressor housing a good yank get it unstuck. It should rotate without removing the snap ring. Mine was "stuck" pretty badly the first time (50000 miles on the turbo) so it took some effort to get the housing to move, but once it broke loose it rotated freely.
Old Jun 21, 2004 | 02:37 PM
EJ1 wilcox's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (fsp31)
To the tizzop yizzo!!
Old Jun 21, 2004 | 08:23 PM
EJ1 wilcox's Avatar
Bump....
because if I can't figure this out soon I'm going to sell this damn turdblow.
Old Jun 22, 2004 | 06:02 AM
fsp31's Avatar
Dude, I'm serious. You don't have to remove the snap ring to clock the turbo. When I said "yank" I meant really hard. I actually used a rubber mallett to get mine unstuck. If it's a well-used turbo, then all the oil coking and crap really sticks the sides together.
Heheh... "turdblow"... I feel your pain.
Old Jun 22, 2004 | 06:20 AM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
You did ? I must be smoking a good la la that day LOL JK
The feed is a 7/16 Inverted flare to a -3AN
the return thread I am not too sure, but I think I did one years ago, it was a 1/2 BSP o-ring boss. If you can measure the diameter of the return hole, I can tell you what it is... and I'll know the thread right away..
I have all the fittings that you need.
Stan
Old Jun 22, 2004 | 06:25 AM
ek9vboi2's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">
Stan</TD></TR></TABLE>
it must be true. u must be smoking that lala. lol...u said the same to me!!!
Old Jun 22, 2004 | 08:10 AM
JalopySiR's Avatar
Have you gone to like a home depot, or -AN fitting store and tried everything they have? I have a T25 from a Pontiac Sunbird and I tried to find the oil drain size, as it was threaded just like yours... I ended up just giving up. I just couldn't find the size. It had to have been some custom size or something...
Old Jun 22, 2004 | 10:22 AM
EJ1 wilcox's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (JalopySiR)
You can see in the first pic above that the edge is beveled a bit...
The nickel fits right inside the bevel and sits on the threads...
And the quarter is about the size of the outside edge of the bevel...
Thanks again for your help Stan
Old Jul 5, 2004 | 11:34 AM
timesnap's Avatar
If you want to wait a couple days I will be headed down to my friends shop where my car is at cuz i just turbo'd my d15b w/ a t25 and went through the same damn problem finding fittings. the small threaded hole where the garrett stamp is, thats the oil feed and the bigger hole is the drain. I know my friend custom made a oil return fitting but i bought an AN fitting for the feed at a local speed shop. I'll get that fitting size for you bro. Go D series turbo ninjas
Old Jul 5, 2004 | 01:18 PM
sporkcrx's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (timesnap)
Whenever I needed fittings for my turbos, I would take them to home-depot's or fitting stores and just find the stuff there.
Old Jul 5, 2004 | 01:28 PM
beepy's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (sporkcrx)
Ah, this is the new-model Garrett T-25. I had one of these for a few days before I completely destroyed it. Long story.
The drain fitting is a massive IF. I don't remember exactly which, but I ended up finding the fitting at a semi-truck outfitter. The inlet size is also one IF size larger than the TD05, if that helps.
BTW, the compressor wheel on this turbo is also different than the older T-25s. This I learned the hard way, as part of that long story.
Old Jul 5, 2004 | 06:03 PM
evosol's Avatar
i got the same probs with clocking and drain fitting. I can clock it but when i loosen the bolts to clock it the center is less than ideal for good feed and drainage.
bump this biiiatch!
Old Jul 15, 2004 | 03:51 PM
IDriveHonda's Avatar
Bump becasue I want to know too.
Old Jul 15, 2004 | 04:00 PM
freakie's Avatar
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (IDriveHonda)
ill go home and measure it up and show u guys some pics, but the thread and fitting that u need are metric defintealy. cos we do things new school
Old Jul 15, 2004 | 04:07 PM
Default Re: Garrett T25 oil return fitting size and clocking issues! *frustrated* (freakie)
Maybe if you could tell us where you bought them, that might help a great deal as well.
Old Jul 23, 2004 | 10:36 PM
I sent an email off to XRP as instructed earlier in this post. Hopefully I will find out the correct drain fitting and can share with everyone.
