what swap should go i go with in the G2?
Old Jun 17, 2004 | 08:05 PM
s2000june's Avatar
Default what swap should go i go with in the G2?
whats the easiest swap to do on a g2 integra LS..
my boy wants to go vtec..
no ls/vtec though . i can do the swap i just dont have experience on obd0 integras. what goes in easiest like gsr or what? any body got any advice lemme know
Old Jun 17, 2004 | 08:26 PM
Sack Master's Avatar
Default Re: what swap should go i go with in the G2? (civicrida3)
I would recommend a gs-r or b16. They will both drop right in. It's the wiring that will probably give you the most problems. If you know what you are doing or are good at wiring then its not hard.
Old Jun 17, 2004 | 08:31 PM
BaGGed HoNDa's Avatar
B18C
Old Jun 17, 2004 | 10:20 PM
..::91TEG-G2::..'s Avatar
Default Re: (BaGGed HoNDa)
has anyone put a H22 in a DA? and u think DA's could fit the K20
Old Jun 17, 2004 | 10:25 PM
Default Re: (..::91TEG-G2::..)
You could fit a 350 chevy in there if you really wanted to. He said easiest though. And a Bseries is a bolt in deal without doing a whole crap load of work.
Old Jun 17, 2004 | 10:35 PM
HARI.'s Avatar
Default Re: (Sack Master)
jdm b18c-r
https://honda-tech.com/zerothread?id=841300
Old Jun 18, 2004 | 03:48 AM
Jer'rome's Avatar
Default Re: (deeaye9)
easiest and prolly cheapest b20z, all you need is the block
Old Jun 18, 2004 | 04:59 AM
RPRacing's Avatar
gsr for the power for money. hybrids are more talking power than horsepower for the money.
i dont like the b20 bottom design.b16 sucks mighty *****
build the damn LS or take the slacker way out and swap a gsr
Old Jun 18, 2004 | 07:20 AM
Default Re: (sucka306)
what do you plan on doing with the car? i.e. turbo or N/A...? if u go with turbo, a b18c1 or b18a/b would be good engines to boost.. and a c5 if u can afford it, and dont wanna do turbo, would be a good idea too..
you can get alot of prob's and respect for building a N/A car that beats wrx's, turbo'd honda/acura's.. and hang with vette's...
or u can just have dirty *** raw hp and blow alot of **** off the street, if u have the right set up and TUNE TUNE TUNE TUNE...
Old Jun 18, 2004 | 08:42 AM
warrick's Avatar
what kind of driving do you do?
do you enjoy revving out, or would you prefer to have a bunch of torque down low?
I'd love to have a k24 in my car, just to keep from having to shift into second to pull out of a corner with any gusto.
mmm low end torque...
Old Jun 18, 2004 | 10:17 AM
nickgmiller04's Avatar
Default Re: what swap should go i go with in the G2? (warric_k)
http://www.g2ic.com
a 1gen obd0 b16 is the easiest swap into a g2.
Old Jun 18, 2004 | 04:26 PM
g2typeryellow's Avatar
Default Re: what swap should go i go with in the G2? (nickgmiller04)
b16 is the easiest for a g2 and one of the cheapest v-tec's out there.
CPreston
Mar 12, 2009 03:08 AM
uses0ap
Aug 27, 2006 09:16 PM
Apollo
26
Sep 4, 2003 01:45 AM
oldirt3277
Sep 18, 2001 09:22 PM
