integra wit CTR cams
Old Jun 18, 2004 | 11:43 AM
vietshinobi's Avatar
Default integra wit CTR cams
i have a gsr and im thinking about put CTR cams in... i was wondering if u felt a difference with in it and if u had to do other mods like ecu, fuel pressure reg., or difference valve springs? thanks for the help...
Old Jun 18, 2004 | 11:51 AM
Phatch99's Avatar
Default Re: integra wit CTR cams (vietshinobi)
bump.... i would like to know this also...
Old Jun 18, 2004 | 12:02 PM
.water's Avatar
Default Re: integra wit CTR cams (Phatch99)
iam sure ur VTEC will scary u more^^...i heard that u have to setup ECU and timming and fuel pressure..yes has to be upgrade
Old Jun 18, 2004 | 12:48 PM
2G0S0R1's Avatar
New User
Default Re: integra wit CTR cams (SpoonKillerB)
With CTR/01 ITR camshafts(pair)
Same low end, if not a loss from the smaller lobe height totals... but vtec definitely hits harder... If you dont raise your vtec point to around 4700 or higher, then you will have a drag/bog between 4400 and 4800 rpms.
A vafc(or any vtec controller) is the minimum requirement, the FPR and ECU will help with tuning but is not necessary for minor bolt ons with cams.
I recommend most of the parts in my sig, although I need to get the VAFC2 tuned... it has all the stock fuel maps right now and fuel pressure was only bumped up a notch... so im not seeing my power potential, and I can feel the non-linear power curve because of this(noticible when punching it from 1k-8k in 1st gear)
I recommend them for a nice upgrade without loosing the honda reliability.
AND IF YOU WANT TO REV HIGHER THAN 8K, GET THE VALVESPRINGS OR YOU WILL FLOAT/BEND VALVES.
Old Jun 18, 2004 | 04:44 PM
AK94GSR's Avatar
Default Re: integra wit CTR cams (2G0S0R1)
i have CTRs in my car aswell, and like them soo far
i also have a PnP head though with valve springs but i did notice a good difference in mid range after tuning. and i make power to 8k now which is nice
Im actually looking to upgrade to skunk stage 2's so if anyone interested in a trade plus cash
Option
May 18, 2004 10:17 PM
envious1320
Oct 19, 2003 07:50 PM
teg1.6
Sep 13, 2001 06:27 PM
SilverVTi
Sep 1, 2001 09:53 AM
