Check Engine light and maintence issues
Old Jun 17, 2004 | 05:40 PM
Blown383's Avatar
Default Check Engine light and maintence issues
I just got a check engine light that came on, my car is a 1996 accord EX V-6. Im assuming its OBD-II but I looked under the dash and there isn't a connector to hook up a diagnostic tool like on my 97 Camaro Z28. How do I check for the trouble code?
Also my car has 112,000 miles on it and on the original timing belt. How difficult is it to swap the belts and water pump? Also what is the going rate for a mechanic to swap this stuff?
-B
Old Jun 17, 2004 | 06:16 PM
Mike813's Avatar
Default Re: Check Engine light and maintence issues (Blown383)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blown383 &raquo;</TD></TR><TR><TD CLASS="quote">I just got a check engine light that came on, my car is a 1996 accord EX V-6. Im assuming its OBD-II but I looked under the dash and there isn't a connector to hook up a diagnostic tool like on my 97 Camaro Z28. How do I check for the trouble code?
-B</TD></TR></TABLE>
if you are new with engine work, i prefer bringing it to a shop, going rate for belt + water pump around my area is like 200 and change...
Old Jun 17, 2004 | 06:56 PM
Chiovnidca's Avatar
It's behind the ashtray.
Old Jun 17, 2004 | 07:36 PM
Blown383's Avatar
Default Re: Check Engine light and maintence issues (Mike813)
Im not new to engine work....well on a Honda yes... It can't be any harder than rebuilding the top end and swapping a cam on a LT1 Camaro.
-B
Old Jun 17, 2004 | 07:37 PM
Blown383's Avatar
I would have never thought to check there! Im going to need a 12 pin ALDL connector to read the code right? Is there software I can download onto a laptop to read the codes?
-B
Old Jun 17, 2004 | 07:48 PM
Conechaser's Avatar
http://home.insightbb.com/~niedejb/refs2.html
the95v6
Jun 13, 2016 04:56 PM
Goodhue911
Oct 31, 2004 07:17 AM
wanna b R
May 6, 2004 04:28 AM
wolfpack005
May 12, 2003 10:52 AM
