LS rods VS GSR rods??
Old Jun 17, 2004 | 04:52 PM
Forrest Gump 9's Avatar
Default LS rods VS GSR rods??
Hey guys, I'm in the process of building my B20 shortblock. I was just wondering if I can use the GSR rods (longer than the stock b20) with the stock b20 crank and pistons to gain some compression? It is a NA application, and daily driver. Thanks in advance.
Old Jun 17, 2004 | 09:52 PM
JDMotive's Avatar
Default Re: LS rods VS GSR rods?? (Turbo9Nut)
Thegsr bearings arent as wide as the ls,i dont know if this would be a major problem,as ive never tried it.I think the pistons would stick pretty far out of the deck,so if youre going to try it,youd better clay your engine to make sure theres no interferance.
Old Jun 17, 2004 | 10:02 PM
Sack Master's Avatar
Default Re: LS rods VS GSR rods?? (JDMotive)
Well you'll PROBABLY(don't know for sure) have to do some machining to get the rods to fit properly. After that you will need a piston with the pin jammed way up in oil control ring completely throwing the centerline off(unless you run some spacer or thicker head gasket then I know of to keep the piston below the deck line). You will sacrafice cylinder wall life but will have a better rod ratio and be able to spin the stroke easier. It's probably not wise to do this unless you are building a drag motor.
vtecmissle
Oct 26, 2005 02:26 PM
hispanic panic
Acura TL, RL & ZDX
Dec 17, 2003 02:45 PM
Spoon Si
Dec 17, 2003 06:50 AM
baybeboi
Oct 5, 2003 06:45 AM
Ri5e
Jul 10, 2002 08:23 PM
