Rebuilding my S1...what synchros/gears do I need?
Old Jun 17, 2004 | 02:59 PM
B16CRXT's Avatar
Default Rebuilding my S1...what synchros/gears do I need?
Ok, I have to rebuild 1st, 3rd, 4th, and 5th in my JDM S1 transmission. I was wondering where I could find what I need and what I would need teh parts from? would synchros from a USDM S1 work or what? Not sur eif I need the actual gears tehmselves or not, but it couldnt hurt to find out what I need for them as well. I am gonn have my tranny oulled apart within a week to see how bad the damage is and see how much it will cost me to fix it. If it is too much I am gonn buy a new tranny (well very low mileage tranny).
TIA!!!
Old Jun 18, 2004 | 01:54 AM
B16CRXT's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (B16CRXT)
Does anybody know? I need to know what I need to rebuild this thing very soon.
BUMP
Old Jun 18, 2004 | 01:07 PM
mmuller's Avatar
Mad Scientist
what about a usdm b-series cable tranny?
i dont see why not
Old Jun 18, 2004 | 02:02 PM
Malgerus's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (mmuller)
The consensus seems to be that you cannot use 90-91 LS synchros in a JDM S1/J1 transmission. You need to find some synchros from Japan. GL.
Old Jun 18, 2004 | 03:00 PM
CHEETAH's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (Mr. S)
some sohc vtec tranny are interchangeable.
greg
Old Jun 21, 2004 | 03:12 PM
ELAMINT5's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (CHEETAH)
so where can we find j1 synchro's
Old Jun 21, 2004 | 06:59 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">some sohc vtec tranny are interchangeable.
greg</TD></TR></TABLE>
But the S1 tranny is for my B series engine. What good would SOHC tranny parts do me?
Old Jul 1, 2004 | 07:21 AM
B16CRXT's Avatar
bump
Old Jul 1, 2004 | 01:57 PM
E-Town4229's Avatar
http://Gear-Speed.com has what you need.
-Roger
Old Jul 1, 2004 | 09:33 PM
Kwuaymaikrup's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (E-Town4229)
The USDM cable synchros WILL work. I have personally done it.
Old Jul 1, 2004 | 10:27 PM
Malgerus's Avatar
Default Re: Rebuilding my S1...what synchros/gears do I need? (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">The USDM cable synchros WILL work. I have personally done it.</TD></TR></TABLE>
You succesfully used 90-91 Integra synchros in a JDM S1/J1? I wonder why everyone says it doesn't work.
Old Jul 1, 2004 | 10:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
You succesfully used 90-91 Integra synchros in a JDM S1/J1? I wonder why everyone says it doesn't work.</TD></TR></TABLE>
That is correct. I am not exactly sure which trans I have (J1/Y1/YS1 yadda yadda) but it is a JDM cable B16 trans with no LSD. I replaced the 3rd gear synchro without a hitch. I think others are still stuck on the JDMness of the trans
Old Jul 2, 2004 | 08:58 AM
rsbad454's Avatar
damn, i hate this stuff.....one person says "Yes they work" and another says "No they dont work" which is it?
Old Jul 8, 2004 | 02:47 AM
Malgerus's Avatar
That is correct. I am not exactly sure which trans I have (J1/Y1/YS1 yadda yadda) but it is a JDM cable B16 trans with no LSD. I replaced the 3rd gear synchro without a hitch. I think others are still stuck on the JDMness of the trans </TD></TR></TABLE>
Very interesting. I would really appreciate it if you could perhaps find out what transmission you have?
Old Jul 8, 2004 | 05:25 AM
B16CRXT's Avatar
I was told by someone that I could use 90-91 LS synchros in my S1 tranny. Is this correct?
Old Jul 8, 2004 | 10:44 AM
Very interesting. I would really appreciate it if you could perhaps find out what transmission you have?</TD></TR></TABLE>
How do it tell? Most JDM trans came with a sticker rather that a riveted on ID tag. Mine has neither. The only other way would be to pull it apart and count the teeth on the gears. I don't think I will be doing that anytime soon. *knock on wood*
Old Jul 8, 2004 | 11:45 AM
Malgerus's Avatar
How do it tell? Most JDM trans came with a sticker rather that a riveted on ID tag. Mine has neither. The only other way would be to pull it apart and count the teeth on the gears. I don't think I will be doing that anytime soon. *knock on wood*</TD></TR></TABLE>
Is it an unmodified transmission? As in no taller fifth gears or anything? What clutch are you using (92+ Integra, or 90-91 Integra)? What is your rpm at 60 mph in fifth gear?
Old Jul 8, 2004 | 07:41 PM
Unmodified except the Quaife. It is the small spline (90-91) and rpms (if I remember correctly) sit at around 4,400 at 70mph in 5th. I haven't driven it in a while so I am not sure but I think that is right.
Old Jul 17, 2004 | 08:41 AM
B16CRXT's Avatar
Ok so my S1 is trashed. I am looking for a new one. Would hmotorsonline or JDMShit get me a good deal on one? Does anybody know of any other sites that sell trannies?
also, I want to know if anyone else has a B16A swap and has their car lowered. If so, does your radius arm hit the tranny? I have a dent in my case from the radius arm....My car was droppped by the previous owner by cutting the spring I think.
JayDM_lsvtec
20
Aug 31, 2005 05:50 AM
tc_gts
May 22, 2005 10:23 AM
JDMF22B
Mar 13, 2005 04:48 AM
boy_wonder69
May 25, 2004 07:32 PM
GS'D YA
Mar 13, 2003 07:04 PM
