failed e-check need help
Old Jun 17, 2004 | 10:59 AM
noble4ws's Avatar
Default failed e-check need help
ok guys first my setup. 92 prelude with 95 h22a. aem intake, and 370cc injectors (the ones that came with the swap werent the right ones) and thats about it for the mods. and i am missing two bolts for my cat and down pipe so theres a little exhaust leak. heres my results
HC 402.1 supposed to be 127
CO 10.04 supposed to be .71
NO 83.4 (passed)
any help is appreciated and i am looking for a way around spending a shitload of money, my mechanic said the injectors are making me run rich causing the high CO and other than get the stock 345cc what can i do about it, he also said the exhaust leak may be screwing up the o2 sensor signal but i will fix that soon, thanks
Old Jun 17, 2004 | 02:48 PM
Chiovnidca's Avatar
Default Re: failed e-check need help (noble4ws)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote">
any help is appreciated and i am looking for a way around spending a shitload of money, my mechanic said the injectors are making me run rich causing the high CO and other than get the stock 345cc what can i do about it, </TD></TR></TABLE>
You may be able to lower the fuel presure to lean it out.
Old Jun 17, 2004 | 04:47 PM
noble4ws's Avatar
whats the cheapest way to do that, just find a regulator, also how will i know how far i am leaning it out
Old Jun 17, 2004 | 05:35 PM
Chiovnidca's Avatar
Default Re: (noble4ws)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote"> also how will i know how far i am leaning it out</TD></TR></TABLE>
A gas analyzer would be nice, or a wideband o2 sensor. Or you could just watch the voltage output of your o2 sensor.
Old Jun 19, 2004 | 07:07 PM
noble4ws's Avatar
bump need more suggestions
Old Jun 19, 2004 | 07:15 PM
non-VTEC's Avatar
sounds like its pig rich.
make sure the o2 sensor is properly working. put in a set of stock injectors and fix your exhaust leak so that the cat can work efficently in buring off the excess gasses.
also check and set your ignition timing..........
Old Jun 19, 2004 | 07:25 PM
noble4ws's Avatar
the timing is dead on and the reason for the 370 injectors is because the swap didnt come with the right injectors and they were cheaper than stock and figured that 370 was close enough to 345. someone had also suggested that i run a one step colder plug, you guys think that would help
Old Jun 19, 2004 | 07:27 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noble4ws &raquo;</TD></TR><TR><TD CLASS="quote"> someone had also suggested that i run a one step colder plug, you guys think that would help</TD></TR></TABLE>
No
Old Jun 19, 2004 | 10:07 PM
v4lu3s's Avatar
RTFM
you are running 10:1 air to fuel ratio
put the right injectors in there.
Old Jun 20, 2004 | 09:00 AM
noble4ws's Avatar
thanks guys
b16sir2000
K Series
Jun 29, 2011 08:32 PM
ahobbs
Jul 14, 2008 09:38 PM
noble4ws
Sep 5, 2004 10:17 PM
Patron
Mar 9, 2004 03:00 PM
stupidfast
Oct 19, 2002 04:04 PM
