timing belt or timing chain?
Old Jun 17, 2004 | 10:43 AM
sslude's Avatar
Default timing belt or timing chain?
okay whats the difference between these two things? what are the ups and downs of both and such? thanks
Old Jun 17, 2004 | 10:44 AM
Jimmy's Avatar
Global Moderator
Old motors and some v8's and **** use timing chains.
I dont really know the difference....ones a chain and ones a rubber belt?
goodluck
Old Jun 17, 2004 | 10:57 AM
Daemione's Avatar
Default Re: (Jimmy)
Not always an old motor that uses a timing chain. The K-series run a timing chain.
A chain has a much longer life than a belt, and in theory will provide more accurate cam timing since it doesn't stretch at all. Downside is expense and noise. Sometimes tricky to install.
Old Jun 17, 2004 | 01:20 PM
rob d's Avatar
Default Re: (Daemione)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">Not always an old motor that uses a timing chain. The K-series run a timing chain.
A chain has a much longer life than a belt, and in theory will provide more accurate cam timing since it doesn't stretch at all. Downside is expense and noise. Sometimes tricky to install.</TD></TR></TABLE>
Chains do stretch. I would say worst than belts. They don't phisicaly stretch. The gear wears down and the rollers in the chain get smaller. This can throw timing way out.
Old Jun 17, 2004 | 01:42 PM
JimBlake's Avatar
Default Re: (rob d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rob d &raquo;</TD></TR><TR><TD CLASS="quote">Chains do stretch. I would say worst than belts. They don't phisicaly stretch. The gear wears down and the rollers in the chain get smaller. This can throw timing way out. </TD></TR></TABLE>True. It usually only takes 300,000 miles for that to happen...
Old Jun 17, 2004 | 02:40 PM
Chiovnidca's Avatar
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">True. It usually only takes 300,000 miles for that to happen...</TD></TR></TABLE>
Never worked on a Chevy huh?
Old Jun 17, 2004 | 03:52 PM
sslude's Avatar
Default Re: (Chiovnidca)
doesnt the f20 and f22 (s2k engines) use a timing chain? well, since it uses a timing chain, do they have special cam gears to adjust timing, or is there something else that they use?
Old Jun 17, 2004 | 05:27 PM
Chiovnidca's Avatar
Default Re: (sslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sslude &raquo;</TD></TR><TR><TD CLASS="quote">doesnt the f20 and f22 (s2k engines) use a timing chain? well, since it uses a timing chain, do they have special cam gears to adjust timing, or is there something else that they use?</TD></TR></TABLE>
Yup, S2000 use a timing chain and the gears that go along with them. I don't beleive there is any adjustment on them.
Old Jun 17, 2004 | 05:41 PM
alloutmotor's Avatar
SR20s use timing chains
Old Jun 17, 2004 | 08:18 PM
sslude's Avatar
Default Re: (alloutmotor)
so there arent any cam gears for them? so the only way to change timing would be a new ecu or EMS right?
Old Jun 17, 2004 | 08:32 PM
mmuller's Avatar
Mad Scientist
no, they make cam gears for chain driven cams
Old Jun 21, 2004 | 04:38 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Never worked on a Chevy huh?</TD></TR></TABLE>Ummm, nope. Good point...
'72 Datsun
'74 BMW
'89 & '01 Saabs
Old Jun 25, 2004 | 07:53 AM
PnX-R's Avatar
Default Re: timing belt or timing chain? (sslude)
Timing chains are said to withstand more horsepower and high rpms...
naeem.ca
Jul 15, 2018 08:06 AM
ziffies
12
Feb 8, 2013 04:50 PM
luvs2spooge
May 18, 2007 05:42 PM
dimsum
Dec 3, 2002 11:28 PM
