running too rich? cel one
Old Jun 17, 2004 | 09:54 AM
Artful Dodger's Avatar
Default running too rich? cel one
I've got an 89 dx hatch with a d16z6 motor in it. I converted to obd1 and have the p28 ecu. I'm getting cel 1, which is the primary o2 sensor. I've checked my wiring many times. Here are the pins.
A25 - black o2 wire
A6 - black o2 wire
D14 - green o2 wire
D22 - white o2 wire
I'm almost positive that these are the right pins which leads me to believe that the o2 sensor itself is bad, but I replaced it less than 2000 miles ago.
The exhaust smells like I'm running rich, which could mean that I've destroyed the o2 sensor. I can also smell gas in the engine compartment and inside the car. When I get really close it smells like its coming from either the fpr or the injectors. The number 2 and 3 cylinder injectors are loose enough so that I can rotate them around in the fuel rail.
I have new injectors and an s-afc that I was gonna install when I put my turbo on, but I was wanted to get the engine running right before attempting that.
**Do you guys think that I should go ahead and put the new injectors in to see if my old injectors were the problem?
**Could it be the fpr?
**What else should I look to?
thanks.
Old Jun 18, 2004 | 06:10 AM
Default Re: running too rich? cel one (Artful Dodger)
bump for my rich ***
Old Jun 18, 2004 | 06:17 AM
Fobtions's Avatar
you most likely have the tps sensor wires backwards.
switch the outer wires around, dont mess with the middle one on the sensor.
Old Jul 1, 2004 | 09:51 PM
Default Re: running too rich? cel one (Fobtions)
I tried switching the tps sensor wires around, but now at wot the revs drop way down. at anything but wot the car acts normal (except for o2 sensor cel). Any other suggestions?
Old Jul 1, 2004 | 10:04 PM
EF_LSVtec's Avatar
I thought you're suppose to splice one of the black wires with the green wire for ground (together), then white wire goes to O2 lead, then the other black wire to a switched power...
http://ludicrous2_0.tripod.com/how_to/oxy/
Old Jul 2, 2004 | 03:50 AM
I converted to obd1, It is supposed to use a four wire o2, anyone else? I'm stumped
Old Jul 6, 2004 | 04:56 PM
anyone?
Old Jul 6, 2004 | 05:17 PM
SiR Inspired ED7's Avatar
Default Re: (Artful Dodger)
damn, that sucks i hope you find some help c'mon h-t members do your thang help a homie out
Old Jul 6, 2004 | 05:18 PM
Bump, keep this thread up until he gets help...
Old Jul 6, 2004 | 05:28 PM
daidilus's Avatar
post in the EG forum. i am sure they will know about your O2 issue
Old Jul 6, 2004 | 07:09 PM
ThatRicerDaniel's Avatar
Default Re: (daidilus)
stock or aftermarket FPR? is the vacum right?
Old Jul 7, 2004 | 03:22 PM
its a stock fpr. I can't find any problems with the vacuum lines
tootybaby
Nov 6, 2009 06:18 PM
crxdx89
Oct 17, 2004 10:08 PM
mugenhatch92
Aug 21, 2004 09:38 AM
quik89
Jul 24, 2004 03:40 PM
Artful Dodger
Jul 14, 2004 04:49 PM
