loose sterring wheel....help.........!!
Old Jun 17, 2004 | 09:52 AM
RACEPAK's Avatar
Default loose sterring wheel....help.........!!
hello everybody.
for about a month my sterring wheel in kinda loose at the center.
when i turn the wheel left & right i here a ticking sound at the center position.
a frined told me that that it's just a bolt to tighten up? what bolt is it??
best regards moshik galimidi
Old Jun 17, 2004 | 10:25 AM
MightyMouseTech's Avatar
Default Re: loose sterring wheel....help.........!! (RACEPAK)
I REALLY doubt it is just a bolt. Sounds like your "friend" does not know what he is talking about. Take the car to a mechanic and get it checked, it is probably one of the four tie-rods that is loose.
Old Jun 17, 2004 | 10:45 AM
RACEPAK's Avatar
Default Re: loose sterring wheel....help.........!! (MightyMouseTech)
the whole sterring was refurblishd last year...
what could lt be??
how is a tie rod look ?
can i fix it on my own??
Old Jun 17, 2004 | 11:23 AM
mastarolla's Avatar
dont play with the tie rod ends unless you have an alignment machine and a lift at your disposal....youll cause yourself a world of hurt unless youre very very familiar with steering and suspension principles.
Basically the tie rods connect in the front just behind the brake rotor...there is a joint which extends to the tie rod itself and then into a black boot (which is your steering rack). Usually if you have small arms you can reach under the backside of the wheel while the car is on the ground and grab the tie rod and shake it around to hear if anything is loose and you can sometimes squeeze in with a flashlight to visually inspect it.
Old Jun 17, 2004 | 12:50 PM
RACEPAK's Avatar
Default Re: loose sterring wheel....help.........!! (mastarolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mastarolla &raquo;</TD></TR><TR><TD CLASS="quote">dont play with the tie rod ends unless you have an alignment machine and a lift at your disposal....youll cause yourself a world of hurt unless youre very very familiar with steering and suspension principles.
Basically the tie rods connect in the front just behind the brake rotor...there is a joint which extends to the tie rod itself and then into a black boot (which is your steering rack). Usually if you have small arms you can reach under the backside of the wheel while the car is on the ground and grab the tie rod and shake it around to hear if anything is loose and you can sometimes squeeze in with a flashlight to visually inspect it.</TD></TR></TABLE>
thank you very much
LeathaFace
Mar 27, 2015 03:16 PM
petwhookie
Suspension & Brakes
Jan 12, 2010 03:22 PM
Jimster480
11
Dec 27, 2009 07:09 PM
Boilermaker1
10
Feb 25, 2004 11:04 PM
smithbling
Mar 13, 2003 01:29 PM
