60 ft. and 1/4
Old Nov 14, 2001 | 11:09 PM
ezark's Avatar
Default 60 ft. and 1/4
i saw some people who listed a 2.0-2.2 60 ft. with stock wheels/tires... how can this be done? i have nitto 555 w/ 16" lenso's (14lbs) ...the best i can get is 2.4 !! i rev up to 2-3k and feather the clutch and apply gas according to how much traction i feel. any suggestions? thanks.
Old Nov 15, 2001 | 12:25 AM
nfn15037's Avatar
Default Re: 60 ft. and 1/4 (krazE)
More RPMS man!!!
Old Nov 15, 2001 | 04:56 AM
Black SVT's Avatar
Default Re: 60 ft. and 1/4 (nfn15037)
The 16's don't help either(if you have stock gearing)
Old Nov 15, 2001 | 06:33 AM
PM-Performance's Avatar
Default Re: 60 ft. and 1/4 (Dc2k-specR)
yea dude launch higher and just drop it, + go with 15's
with my stock street tires, i was getting 2.3
im at 2.0 now with my slicks , but will go down to 1.8-1.9 this weekend , i have a new clutch so i can dump it higher rpm now
Old Nov 15, 2001 | 06:47 AM
nekkedR's Avatar
Default Re: 60 ft. and 1/4 (itr206)
my best 60' is after i installed my Z10 bars, i had a 2.08 60' and the bars werent pre loaded the whole way(maybe one turn)but i ran my best 1/4 time(13.9) with a 2.27 60'. i rev the car around 5000-5500 and ride the clutch till it hits vtec and then let it out,80000 miles on my stock clutch so it cant hurt that bad
Old Nov 15, 2001 | 06:54 AM
BoM's Avatar
BoM
Default Re: 60 ft. and 1/4 (nekkedR)
be as hard on your tires as you can!
burn them 555's up!
then just launch at 5k and get it to grip
feathering.
2.2 with toyo Fz4's and they suck!!
Old Nov 15, 2001 | 08:00 AM
05 600RR's Avatar
I have the BFG Drag radials and my best 60' time w/22lbs. is 2.175. my time was 14.6, and the track is @ 4500 ft. elev. That was launching @ 7300 rpm.
Old Nov 15, 2001 | 08:16 AM
GRM Scott's Avatar
25 Year Member
Default Re: 60 ft. and 1/4 (01 ITR 01-0492)
I got a 2.28 on 215/40 R16 pirelli P7000s, which don't actually stick as well as my RE010s did...27 PSI, it was cold as hell, the wheels were volks which probably didn't hurt. Lauched from about 4500 RPM, did not feather clutch.
Old Nov 15, 2001 | 08:33 AM
SpeedRacer00-667's Avatar
Default Re: 60 ft. and 1/4 (Aleph)
you got to lauch higher, no lower than 6krpm and maybe as high as 7.5krpm, good luck
Old Nov 15, 2001 | 08:35 AM
ezark's Avatar
wow, i suppose i should try two things next time:
1. dumping the clutch fully at 5k with gradually applying gas depending on traction
2. feathering out the clutch from higher than 5k
thanks
[Modified by krazE, 5:35 PM 11/15/2001]
Old Nov 15, 2001 | 08:42 AM
BryanSprinkel's Avatar
I wouldnt just dump it. It takes practice, a lot of it. Just try different things, different RPMs, and the feathering thing works. I pull a few 2.0 on Nitto drag radials. On street tires I could do 2.2's prety much all day long. I run 22-24 PSI in the drag radials, and about 27-29 in the RE010's. Good luck... PRACTICE
Bryan
Old Nov 15, 2001 | 09:24 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
yeah dump that **** higher. With my stockers, I couldn't get better than 2.4, but central florida tracks suck. Gotta test out my new tires though
Old Nov 15, 2001 | 09:38 AM
py1188's Avatar
Default Re: 60 ft. and 1/4 (RealTypeR)
I used to pull 2.0s on Nitto Drag Radials as well. Its all about the practice and learning what works best for you and your car. You could dump or feather, depending what kind of wear you don't mind putting on that clutch and tranny. I tried to find a happy medium, not necessarily dumping at 5-6k, but not necesarrily fetahering either. Just PRACTICE!!
Old Nov 15, 2001 | 09:43 AM
ezark's Avatar
Default Re: 60 ft. and 1/4 (py1188)
thanks, i been practicing for 1 year now. going to the track every couple of weeks :/ another thing, i'm not LSD equipped like you R's
Old Nov 15, 2001 | 09:53 AM
Try running a little less air in the right front. On street tires, 23 on right side, and 25-27 ont he left front. I think that is what i used to run in my 99 Si.
Bryan
papa5murf
Honda S2000
11
May 10, 2004 12:54 PM
.M.
Mar 28, 2004 03:07 AM
tallblondkid
Aug 5, 2003 03:03 PM
memphiss13
Jul 3, 2002 10:18 AM
SoulSurfer
Jun 25, 2002 04:22 PM
