Cage and seat install - Major problem
Old Jun 17, 2004 | 06:57 AM
Ex-ITR5874's Avatar
Default Cage and seat install - Major problem
Hey ITR people,
to make a long story short: My rollcage is installed in the car and now it fits wonderful.
So the problem:
This is my seat (I choosed it in black. This image is taken from the website of OMP)
OMP Type "Grip"
Those are my brackets (HC733):
I also have sliders. But if I put in everything, means the console, the sliders and the brackets and the seat in the lowest position, the seat sits way to high.
So we put the sliders out and the seat is still way toooooo high. I touch the cage with my head. Further, the seat would sit to close to the steering wheel when just bolted to the stock position.. I need to bolt on the seat 110mm further away.
Problems problems......... Next race event is 17th of July...
Has there anybody solved a similar problem ?
Old Jun 17, 2004 | 07:02 AM
mstewar's Avatar
Default Re: Cage and seat install - Major problem (ITR5874)
you need either to fab custom sliders/mounts, or buy a different seat methinks..
the mugen sliders supposedly sit the lowest of the pre-made ones, IIRC, but I'm not sure that's low enough for you..
Old Jun 17, 2004 | 07:13 AM
Ex-ITR5874's Avatar
Default Re: Cage and seat install - Major problem (mstewar)
I am very tall... But the stock seat height seems to work for me...
Those OMP seats are legal on my car.. others are not (except stock for sure). So those seats have to get in the car anyway.
Old Jun 17, 2004 | 07:19 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar &raquo;</TD></TR><TR><TD CLASS="quote">the mugen sliders supposedly sit the lowest of the pre-made ones, IIRC, but I'm not sure that's low enough for you..</TD></TR></TABLE>
They dont work with all seats though
Old Jun 17, 2004 | 07:23 AM
Ex-ITR5874's Avatar
Default Re: Cage and seat install - Major problem (.RJ)
I need brackets that allow the seat to drop lower... Much lower
Old Jun 17, 2004 | 07:55 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR5874 &raquo;</TD></TR><TR><TD CLASS="quote">I need brackets that allow the seat to drop lower... Much lower</TD></TR></TABLE>
sounds like you're going to have to make some then.. get some OEM sliders and whatever mounts you need and either have someone do it, or make em yourself..
Old Jun 17, 2004 | 08:01 AM
Ex-ITR5874's Avatar
yeah... that might be how this story ends.... Or I have to live with my JDM Recaros and sell the OMP seats... damn.
Old Jun 17, 2004 | 08:56 AM
Big Phat R's Avatar
I have the same problem in my car.
You will need to make a custom mount for the seat brackets.
Taking out the cushion will drop you down a bit - but sitting on the hard seat is not fun.
You can try switching the brackets left to right so that the bracket angles AWAY from the seat base. This way - the brackets will not limit how low you can mount the seat - but this will require you to fab up a custom base.
I use the HC 733 on my Type R
BPR - who is doing the same thing on his car....
Old Jun 17, 2004 | 11:20 AM
MissMyHonda's Avatar
we'd make you up some brackets, but we'd need the seat or ur current brackets and some good details on what you want done or REALLY REALLY good measurements
Old Jun 17, 2004 | 11:39 AM
Austin's Avatar
Default Re: (JoesTypeS)
Side mount, or bottom mount seat?
I have a Sparco Evo2 in my car, and I modified the OEM rails and the Sparco brackets to fit the seat in. With all of the pads in place I'm about stock heigth, withouth the big front bolster I'm lower than stock, and without any of the padding(what I prefer for the track, only 25 minute sessions so far, and autocrossing) I'm way lower than stock.
Austin
Old Jun 17, 2004 | 04:06 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (Austin)
I'd find a race fab shop in your area and have them custom mounts and sliders for you if you're not savvy enough to do it yourself. It's usually not more than 2-300, which may or may not be worth it to you.
Old Jun 17, 2004 | 06:07 PM
Dr Pooface's Avatar
Default Re: (SkyeC)
Go custom. There is no other way you'll get it lower.
Old Jun 17, 2004 | 06:15 PM
Dan GSR's Avatar
Default Re: (Dr Pooface)
I just mounted a carbon/kevlar grip in my integra
I wish it were a little lower as well, but it works for me
I used the OMP base, and aluminum side mounts
Old Jun 17, 2004 | 06:18 PM
BlueR's Avatar
Default Re: (Dan GSR)
C's robo shifter
Old Jun 17, 2004 | 06:21 PM
Dan GSR's Avatar
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">C's robo shifter </TD></TR></TABLE>
Old Jun 17, 2004 | 06:22 PM
Dan GSR's Avatar
you could try to weld the side mounts to the base where u want it
Old Jun 17, 2004 | 06:25 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">you could try to weld the side mounts to the base where u want it</TD></TR></TABLE>
thats what i did and got about an extra inch of headroom
Old Jun 17, 2004 | 06:27 PM
Dan GSR's Avatar
Default Re: (BlueR)
yeah, now i wish i had the steel side mounts, so i could do the same
Old Jun 17, 2004 | 06:29 PM
BlueR's Avatar
you still can, sparco steel sidemounts are pretty cheap
Old Jun 17, 2004 | 06:31 PM
Dan GSR's Avatar
Default Re: (BlueR)
i don't think they will fit
Old Jun 17, 2004 | 08:16 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
shifter = :blort:
Old Jun 17, 2004 | 08:26 PM
JDM Factor's Avatar
Sounds like you need smaller/shorter seat brackets. When I installed the Sparco Milano's in my R the Sparco seat brackets were not already pre-drilled. However, thankfully we could choose where we wanted to mount it. If you don't find a bracket available for your height adjustment, buy the Sparco seat brackets. Then you can choose where ever you want it.
Old Jun 18, 2004 | 02:09 AM
Ex-ITR5874's Avatar
Default Re: (JDM Factor)
Hmmm..
A friend has the same seat installed, but he took other brackets... I guess they are in the image above also.. No. HC/732.
Here is the pic:
I sat in his ITR a while ago and remember that it worked fair well.
I will get those brackets saturday morning and see if we can work this out right.
Old Jun 18, 2004 | 04:07 AM
Dan GSR's Avatar
Default Re: (ITR5874)
those are the same side mounts I have
Old Jun 18, 2004 | 05:46 AM
Ex-ITR5874's Avatar
But are they really lower than the others ?? On the pic I doubt it...
Compare HC/732 and HC/733
