first time at track... a little depressed
i went to the track last night for the first time ever and was pissed with my numbers. you guys tell me what you think.
im runninmy civic with a sohc d16z6 with the greddy kit and blue box at 7psi toyo proxies and lightened flywheel.
i guess im just a shitty driver cuz my friend ran 16.2 in his civic with I/h/e
1st run
r/t....... .435
60....... 2.937
330..... 7.475
1/8...... 11.068
mph ..... 70.03
1000..... 14.187
1/4 ...... 16.808
mph ..... 86.43
2nd run
r/t ...... .352
60 ...... 2.477
330 ...... 6.932
1/8 ..... 10.540
mph..... 69.76
1000 .... 13.577
1/4 ...... 16.140
mph ...... 87.58
1st run
r/t....... .435
60....... 2.937
330..... 7.475
1/8...... 11.068
mph ..... 70.03
1000..... 14.187
1/4 ...... 16.808
mph ..... 86.43
2nd run
r/t ...... .352
60 ...... 2.477
330 ...... 6.932
1/8 ..... 10.540
mph..... 69.76
1000 .... 13.577
1/4 ...... 16.140
mph ...... 87.58
Keep practicing. it will get better, look at the improvement between the first and second runs. Your 60ft time could use some work, but just keep going until you get it down and you will see better results
when i turned up the boost a little i started messing with the bov (hks ssq) and now it sounds like im leaking a lot of air when shes spoolin up but the guage still reads 7psi so im not sure what to do or if thats my problem. i tried to play with that damn screw in and out and it doesn't seem to make a difference in the air rushing sound. maybe thats my problem?
Get that 60' down to like 2.1 or 2.0 and youll get better times.. With your setup I still think there might be something wrong..
his trap speeds are very low too
the ET are ok for the trap speeds
but again, i ran a 15.1@ 89mph with 120 whp
if he drops the 60 foot to about 2.1 and gains about 9 mph on the trap,. then he sure can get a 14 sec car out of it
Your mph is just not there.
What altitude are you at? What's the condition of the engine? I'd expect at least mid-to-low-90 mph from your setup.
what do you launch at? how's traction of the launch?
like the others said, bring down the 60' and you'll be doing much better.
what condition are you tires in? if you've lowered your car have you had it re-aligned or added a camber kit?
i'd say your just spining the tires too much of the launch.
dragged at lebanon valley i would guess like 900 ft elevation
good tires stock shocks and height and stuff
first launch sucked almost bogged it out
second launch was better didnt burn out much just long chirp and it felt good
i was launching at like 2500 and shifting a little early i think like 6500
today i tightened up the bov and it seemed to spool faster now but maybe im imagining it. ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">
In this case I think it's both the car AND driver.</TD></TR></TABLE>
C'mon... let's be constructive. NVM the 60' and the ET, a stock CRX Si will pull those mph's in the 1/4 mile. Unless he's shifting like grandma or hitting the rev limiter like there's no tomorrow, something's wrong.
it doesnt seem to pull as hard in the top end as it should.
vtec is working so should i adjust timing for more top end?
or should i just shift sooner so i dont come anywhere near redline?
also i really think somethin was wrong with my bov. i tightened it up alot and it seems to have helped and the air rushing sound calmed down. but it could be all in my head, you know what i want to think.
yeah hahah
no i didnt have any subs in
still had the spare and alot of tools but not that much weight.
i think im going to crank up the boost to 8 and go next week to try again.
ditch the poo box
get real tune, hondata if you want to pay someone to do it
uberdata if you want to pay less and learn a **** load then do it your self
aem ems blah blah
throw that blue box off a cliff
aem ems blah blah
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skierGT »</TD></TR><TR><TD CLASS="quote">dragged at lebanon valley i would guess like 900 ft elevation
today i tightened up the bov and it seemed to spool faster now but maybe im imagining it. ??</TD></TR></TABLE>
i hate lebanon valley, that track is ****
