H22A oil pressure
Old Jun 16, 2004 | 07:52 PM
Lolouis's Avatar
Default H22A oil pressure
I have a H22A. After I installed the oil pressure meter, I begin to worry my engine.
The meter shows below:
cool engine start - 6 kPa and goes down slowly when engine warm up
normal driving - 2~6 kPa
when idle - 1 kPa after few minutes driving
After 3-4 mins hard driving:
idle - 0.5 kPa
I worry the oil pressure is too low and the engine has something wrong.
Is there anyone can tell the H22A normal oil pressure is?
Old Jun 17, 2004 | 07:39 AM
Ekasey's Avatar
Default Re: H22A oil pressure (Lolouis)
not to be a dick but convert your numbers,
kpa = gay
according to your given info using kilopascals
your oil pressure is
cool engine start 6 kPA - 0.870808 (below 1 psi)
normal driving 2-6 kPA - 0.290269 - 0.870808
Your oil pressure at idle should be near 35 psi , and around 65-75 under load. SO there is couple possible wrong things here.
1. Your reading the gauge wrong
2. You hooked up the gauge wrong
3. That **** is broke (the gauge)
4. Your engine should be a motlen chuknk of metal resulting form excess heat created from oil flow
5. YOU SMOKE ENTIRLEY TOO MUCH CRACK
your gauge read in kPa X100??????
recheck the provided info is your dash oil light on.? that goes on when there is 5 psi oi lress of oil pressure
Old Jun 18, 2004 | 02:21 AM
Lolouis's Avatar
Default Re: H22A oil pressure (eLusive ek4)
Hi EK4,
Actually, there is no waring light from dash.
I am quite confusing coz fews ppl told me that H22A should have a lower oil pressure that the B18C, B16B and other VTEC engines. And there is no any strange noise and smoke from engine.
Louis
Old Jun 18, 2004 | 07:21 AM
Ekasey's Avatar
yeah i would tend to bank on the gauge then is your stock oil pressure sensor hooked up?
88h22_CRX
Oct 31, 2014 05:41 AM
TeamSeanFTW
Mar 15, 2011 06:41 PM
ProjectBB6
Sep 16, 2009 02:18 PM
vlang29
Apr 21, 2008 02:36 PM
CaNaBiS
Feb 3, 2004 01:30 PM
