where is the main relay on a 1991 civic si hatch?
Old Jun 16, 2004 | 06:56 PM
typeeg's Avatar
Default where is the main relay on a 1991 civic si hatch?
And can a faulty main relay also cause a car to crank and sputter and not start? Thanks
Old Jun 16, 2004 | 07:11 PM
hatchblack's Avatar
Default Re: where is the main relay on a 1991 civic si hatch? (StockEG9)
the main relay is located to the left of the fuse panel - it's tucked up behind part of the dashboard next to the fuse panel. there is one screw holding the small bracket attached to the main relay to hold it against the for lack of a better description, inner fender of the car - it's bolted to the side. basically, take the underdash fuse panel cover off, look behind the dashboard just to the left of the panel cover and you should see it.
Old Jun 16, 2004 | 08:07 PM
typeeg's Avatar
Default Re: where is the main relay on a 1991 civic si hatch? (hatchblack)
how can you tell if its bad or not?
Old Jun 16, 2004 | 08:31 PM
Redline130's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell if its bad or not?</TD></TR></TABLE>
If you can't hear your fuel pump priming, then your main relay is shot. You'll know when your car won't start, it will just crank over, especially on hot days.
Old Jun 16, 2004 | 09:14 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: where is the main relay on a 1991 civic si hatch? (Redline130)
what screw is holding it? a 10 mm bolt?
Old Jun 16, 2004 | 09:33 PM
SC0TT's Avatar
Dont unscrew it!!! Its so much easier if you just take out the internals, leaving the outter shell/case bolted in. Trust me, its a bitch getting the little bolt back in.
Old Jun 18, 2004 | 01:13 AM
SiR Kid's Avatar
New User
Default Re: (SC0TT)
I just unplugged it, and plugged the new relay in, so they are both shoved up under the dash. Took &lt;2 minutes to do.
Old Jun 18, 2004 | 06:40 AM
WhatThaFrig's Avatar
Default Re: (SiR Kid)
The main relay is a bitch to get to!
Old Jun 18, 2004 | 07:46 AM
SIRMcD's Avatar
http://autorepair.about.com/gi...y.htm
Check yer ignitor as well.
Old Jun 18, 2004 | 11:25 AM
letholone's Avatar
Default Re: (SIRMcD)
i just had this same thing happen last weekend....
it was my actual fuel pump itself.
98typerar
14
Jan 25, 2014 03:34 PM
shwanC
15
Dec 4, 2013 12:31 PM
CaNaBiS
Sep 23, 2002 02:17 AM
