CIVIC 2000 hub removal!!! HELP
Old Jun 16, 2004 | 05:11 PM
lDanny's Avatar
Default CIVIC 2000 hub removal!!! HELP
I cant seem to pull the hub off.. i got the axle nut off but i cant get the hub off .. any ideas? I need to replace a broke stud!!
Old Jun 16, 2004 | 06:27 PM
beaterdriver's Avatar
if you want to take the whole entire assembly off you have to remove the lower ball joint, upper ball joint bolts and i think the tie rod bolt. but the bearing has to be pressed out
Old Jun 17, 2004 | 02:06 AM
lDanny's Avatar
Default Re: (beaterdriver)
i just need to get the studs/ hub out..
Old Jun 17, 2004 | 11:12 AM
ykracing's Avatar
Default Re: (DuMa)
well the hub needs to be pressed out of the bearing. and it will likely trash the bearing at the same time, so you might as well get a new bearing before you get started.
civicsi98
14
Mar 14, 2017 09:13 AM
Mark1127
Classic Hondas
May 30, 2010 10:32 AM
phrenzykEG6
May 5, 2010 04:20 PM
jdm*Stars
10
Jun 20, 2005 01:45 PM
sivik2nr
Oct 1, 2002 07:27 PM
