Coolant leaking overnight...bad water pump?
Old Jun 16, 2004 | 04:25 PM
RedRyda's Avatar
Default Coolant leaking overnight...bad water pump?
I have a '94 EX and every morning we noticed a puddle of coolant under the car behind the driver's side tire. I'm suspecting a bad water pump, but the engine never runs hot and it only leaks after the car sits overnight (so it seems). I had this same problem with a '90 Civic Hatch that I owned, but I sold it before I could figure out the problem. Has anyone else encountered this and am I safe in assuming that the water pump needs replacing? I'm currently in the middle of an ISB change on this car and really don't want to go straight into a water pump install after I'm done.
Old Jun 16, 2004 | 04:39 PM
Swapped_EG's Avatar
Default Re: Coolant leaking overnight...bad water pump? (RedRyda)
It could very possibly be the water pump. The water pump on my B16 was bad and it never over heated. The ghetto way to finde out is take the timing belt cover off and drive around a little bit. If it throws a lot of **** up on your hood thats prolly what it is. Hope you figure it out.
Old Jun 16, 2004 | 04:41 PM
Swapped_EG's Avatar
It could very possibly be the water pump. The water pump on my B16 was bad and it never over heated. The ghetto way to find out is take the timing belt cover off and drive around a little bit. If it throws a lot of **** up on the under side of the hood thats prolly what it is. Hope you figure it out.
WingedMan
Apr 26, 2021 05:03 PM
niceprelude
Feb 15, 2009 10:20 PM
mike0503
Jul 11, 2007 04:54 PM
Mr_Moos
Jun 24, 2007 10:04 PM
dclub01
Apr 5, 2003 01:50 PM
