92 CIVIC HB Automatic trans to Integra GSR Manual swap
Has anybody done this?
I'm about to do it but apprehensive about the clutch stuff and converting the auto lever to manual.
Is this something that can easily be done or should I just stick with the auto trans.
Thanks for the advice.
Pretty straight forward from what i hear but you will need the clutch pedal assembly, the hydraulic line and the shifter assembly. For a clean install you should also swap the cluster but it's not necessary.
I haven't done the swap myself i'm just quoting from my enclclopedic knowledge of the Helms manual.
Mike
Mike
