Changing headgasket. Need help!@!
Old Jun 16, 2004 | 12:49 PM
Red D Dragon's Avatar
Default Changing headgasket. Need help!@!
I am going to attempt to change my headgasket this weekend. I was planning on having my head milled to increase my compression up to around 11.0:1 what is a safe amount to mill the head? its a stock gsr bottom end running skunk stage 2's. Also what other gaskets should i replace. I mean which ones can i more then likely reuse and which ones am i better of replacing. Also do i need to get a new timing belt tensioner or can i reuse the one i have. its pretty new. only a couple thousand miles on it. any help would be awesome. Thanks.
Old Jun 16, 2004 | 12:54 PM
StyleTEG's Avatar
Default Re: Changing headgasket. Need help!@! (Red D Dragon)
Safe is .03" off, which will require about 2.5 degree's of advance
With milling you can hit 10.7:1
Old Jun 16, 2004 | 03:13 PM
so three thousanths would be alright... what would give me 11.0:1 compression with a stock gsr bottom end? and what gaskets should i replace..
Old Jun 16, 2004 | 04:29 PM
StyleTEG's Avatar
Default Re: (Red D Dragon)
You could look into getting flat top valves.
Cam seal gaskets wouldn't be a bad idea.
jp97lude
Dec 10, 2007 04:16 PM
b18cvtec
Jan 30, 2007 05:53 PM
b17boost
Oct 18, 2005 07:10 PM
Icey112
May 21, 2004 01:30 PM
McFly
Mar 29, 2003 12:38 PM
