Transmission swap
Old Jun 16, 2004 | 12:16 PM
fireslinge's Avatar
Default Transmission swap
Im in the process of swaping my ss tranny to a manual 5 speed. Do i need diffrent tranny mounts and if so does anyone know where to get them?
Old Jun 16, 2004 | 12:20 PM
naujcdl's Avatar
Default Re: Transmission swap (fireslinge)
Yep, you are needing them, i'd try talking to http://www.importautosalvage.com
my friend just finished his swap and it is awesome, let's say the car is different.
http://www.chicagolandpreludec...st=30
Old Jun 16, 2004 | 12:31 PM
fireslinge's Avatar
Default Re: Transmission swap (naujcdl)
did he swap a jdm transmission or a usdm and does that matter minus the gearing ratios?
Old Jun 16, 2004 | 12:42 PM
naujcdl's Avatar
He installed an h23 5 speed trans on his, that car is insane now, you see all the specs throught the post.
Hint: Do it right the first time.
ps. the usdm h22 trans from the 5th gen is a pos (gears are bad and it is just bad), please go with an h23 trans or jdm h22 trans.
Old Jun 16, 2004 | 12:57 PM
fireslinge's Avatar
yeah my plans were for an jdm lsd or the h23 one
Old Jun 16, 2004 | 03:04 PM
Zimmlude's Avatar
FYI, the H22 tranny's (whether they be JDM 5th gen, 4th gen, ect...) all have the same problems. My M2B4 JDM LSD tranny has the 5th gear grind just like all the rest.
Not to steal the thread but I have an M2S4 H23 tranny from my Si for sale. It has 81XXX miles on it and NEVER had a problem, e-mail at jwzimm@u.washington.edu if interested.
Old Jun 17, 2004 | 06:47 AM
fireslinge's Avatar
From what it looks like in that post did he get a second ecu written to because of the immobilizer?
Old Jun 17, 2004 | 06:59 AM
fastludeh22's Avatar
ya dont use h23 tranny. gears suck compared to h22 ones. 4th gen are better then 5th gen, but all are good.
all manuels have the same prob, the syncros
Old Jun 24, 2004 | 07:56 AM
fireslinge's Avatar
Default Re: Transmission swap (fastludeh22)
But if im going turbo woudnt the h23 one be better? I know i didnt say it before but thats the plan... 5 speed swap.. internals and then nice little drag 3 kit
Old Jun 24, 2004 | 08:22 AM
gerhard's Avatar
Ok, the ECU's:
You can get the manual ECU, but the year compatbility is:
97/98
99/00/01
The grouped years will work in those model year preludes. You can not use ECUs from another group above in a different group. In otherwords, a 97 ECU will not work in a 99 or vise-versa.
You can convert you auto ECU to run properly as a manual by changing a resistor on the motherboard of the ECU. You need to be GOOD a micro soldering.
You can also remove the immobilizer daughterboard from the auto ECU and plug it into the manual ECU... and the car will start right up.
Otherwise, you need a key from the manually equiped ECU and it's immobilizer to start your car with the new ECU (using duplicated T5 keys), OR to have Honda reprogram the ECU/immobilizer using the Red Key.
Old Jun 24, 2004 | 09:58 AM
fireslinge's Avatar
Default Re: Transmission swap (gerhard)
Old Jun 24, 2004 | 02:50 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireslinge &raquo;</TD></TR><TR><TD CLASS="quote">But if im going turbo woudnt the h23 one be better? I know i didnt say it before but thats the plan... 5 speed swap.. internals and then nice little drag 3 kit</TD></TR></TABLE>
i would find an h23 tranny and slap a quafie in there
if you plan on turboing and are going to be spending
money on the transmission
Old Jun 24, 2004 | 05:44 PM
SunShine287's Avatar
Default Re: Transmission swap (SKDRCR)
Whoa... whoa...
I'm in the market for a tranny swap on my 2000 SS... will an h23 tranny actually fit in? Should i go for the JDM h22? I do plan on going turbo... eventually.
Old Jun 26, 2004 | 08:31 AM
fireslinge's Avatar
Default Re: Transmission swap (SunShine287)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SunShine287 &raquo;</TD></TR><TR><TD CLASS="quote">Whoa... whoa...
I'm in the market for a tranny swap on my 2000 SS... will an h23 tranny actually fit in? Should i go for the JDM h22? I do plan on going turbo... eventually.</TD></TR></TABLE>
yes the h23 fits... way to jack the thread...
erk89
Dec 23, 2008 04:23 PM
preludedriva
Sep 26, 2006 12:17 PM
hprelude93
Sep 26, 2005 11:38 AM
fenominal
Jul 22, 2004 07:27 AM
Arch-Angel
Aug 30, 2002 10:11 AM
