Fitting rear ITR shocks on 88hf rear lower control arms?
Is there any modifications needed to make this work properly? I have some omni powers on the way and they are for 94-up ITR style. I have 92-95 civic forks for the front already and im running an 88hf rear lower control arm setup. Do i need to mod the shock/control arms to make it work?
the itr rear shocks bolt right into 88 style rear LCA's, as for the front forks...arent those an inch longer/higher than the ef ones?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer »</TD></TR><TR><TD CLASS="quote">as for the front forks...arent those an inch longer/higher than the ef ones?</TD></TR></TABLE>
No they are the same length.
