Engine Check LED on
Old Jun 16, 2004 | 07:18 AM
chansw's Avatar
Default Engine Check LED on
hi, I was on a 230km business trip. I rev more than 4.5krpm every now and then until the 5th or 6th time, engine check LED turned on, I continued to drive normally for another 1 hour or so, until I ran out of gas and refilled. After which the engine check LED did not turn on again.
On my way home, I drove hard a few more times, each time about 30 seconds - 1 minute, and engine check turned on shortly after.
Checked the oil level at cool engine, it's OK. Is there something wrong with my VTEC?
It's a right-hand-drive CD5, where can I find the switch to get the code?
Help appreciated, merci beaucoup!!
Old Jun 16, 2004 | 10:08 AM
The_Todd's Avatar
Farts in the shower
Default Re: Engine Check LED on (chansw)
If it is a RHD cd5....I would check the opposite side (glove compartment) and pull the code
Old Jun 20, 2004 | 07:07 AM
chansw's Avatar
Default Re: Engine Check LED on (VRDrvr)
Greetings,
Ok found the blue connector thanks, jumped it and found code 22. I believe it's something to do with the Oil Pressure Switch or its circuit. Will get this checked sometime soon....
Merci mille fois
Old Jun 20, 2004 | 10:38 AM
hondadude's Avatar
Vtec solenoid base gaskets are known leakers.
Old Jun 20, 2004 | 11:58 PM
chansw's Avatar
Default Re: Engine Check LED on (hondadude)
And one of my friends did mention to me that VTEC is "quite a reliable" thingy. How much does it cost to fix a code 22 in general & worst case scenario?
Thanks!
Old Jun 22, 2004 | 06:11 AM
chansw's Avatar
Hi,
VTEC solenoid is good, but serviced.
Replaced with new Oil Pressure Switch, first, second & third rev up to 6krpm & maintain rev, OK, fourth try gives CEL right after hitting 4krpm, pulled the code just now still #22. What else could causing the problem???
Pleeeease help!! Thanks!!
Chan
Old Jun 26, 2004 | 05:27 AM
chansw's Avatar
Bump.
Anyone has a thought? I'm quite stuck!
Thanks!
Old Jun 26, 2004 | 07:08 AM
Riceburner247's Avatar
And you said you had enough oil, right?
Old Jun 26, 2004 | 07:12 AM
The_Todd's Avatar
Farts in the shower
Default Re: Engine Check LED on (riceburner247)
The only thing I could see causing it is either a bad vtec solenoid, oil pressure sensor (cirucits or sensor). Possibly a seal, but check the oil first and foremost. Make sure you check it cold and also after it has reached operating temp.
Old Jun 27, 2004 | 06:34 AM
chansw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner247 &raquo;</TD></TR><TR><TD CLASS="quote">And you said you had enough oil, right?</TD></TR></TABLE>
Yes sir.
Old Jun 27, 2004 | 06:38 AM
chansw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">The only thing I could see causing it is either a bad vtec solenoid, oil pressure sensor (cirucits or sensor). Possibly a seal, but check the oil first and foremost. Make sure you check it cold and also after it has reached operating temp.</TD></TR></TABLE>
Ok I've missed out the checking oil at operating temperature part. How much will the oil-indicator drop at operating temp compare to cold?
Thank you!
STR8__
K Series
Mar 7, 2017 08:20 AM
DOHC4VTEC
Mar 21, 2008 12:30 PM
roller
Jun 13, 2004 11:57 PM
turtleb16a
Oct 28, 2002 10:29 AM
