Clutch Problem
I put the b16a2 complete changeover about 2 months ago and the other day i was driving and my car fought me to go into gear. After forcing it in a few times it resisted to the point where it wouldn't go into gear at all. Is it my clutch? slave cylinder? tranny? HELP PLEASE
do you mean when you try to shift in to lets say third it feels like your poping it in to gear with out using a clutch?
If so i think it might be the clutch. i little while back i popped a spring in my clutch and it did the exact same thing
no it is sitting in my garage right now and it will not go into any gear when the car is on. i put it in first and then started it and it bucked and shuttered out of control. also when i have the car in neutral and push the clutch down, there is a little dead zone and then it vibrates and if i push the clutch down and go to put it into a gear(even tho it wont go in) it feels like the car is going to stall.
It could be your slave cylinder. I have seen them blow and when you push the clutch pedal, they will not function. Get someone to push the clutch and see if the arm will move all the way when you do it.
old_school_dohcvtec
Oct 4, 2007 09:47 AM
