Need tips for h22 swap into 94 accord
Old Jun 16, 2004 | 05:55 AM
mrpaperpaper's Avatar
Default Need tips for h22 swap into 94 accord
does anyone know if the powersteering hose and a/c lines from a 94 honda accord EX fit an H22a1? Im going to do this swap pretty soon, here in a few weeks. I would just like to get some helpfull tips and hints before I start up the project. Any wiring problems I should look out for, etc.? Does my axle fit and shift linkage fit, or do I need to swap them out as well? And Someone also told me that the Accord tranny bolts on to the H22, just different gear ratios, is that true?
Old Jun 16, 2004 | 06:34 AM
AndyD's Avatar
Default Re: Need tips for h22 swap into 94 accord (mrpaperpaper)
I have a Honda Tuner magazine that shows the procedures for this swap. I know they had to do some welding for the power steering line. That should be the only accessory that needs some custom work.
I think you will need to run wires for the knock sensor. Not sure. I will check on that.
Also, I believe they mentioned something about using the Accord TB if you wanted to keep cruise control.
I will look at the article tonight and let you know what else is needed.
Old Jun 17, 2004 | 04:34 PM
Ala_2DrAccord's Avatar
hey im lookin for like a parts list or something like that for the same swap into a 94 2dr and if anyone has tried to use a sds type management instead of the normal ecu
Old Jun 18, 2004 | 06:13 AM
Default Re: Need tips for h22 swap into 94 accord (AndyD)
hey yo thanks for the tips. Im going to need it. About the knock sensor, If I already have the sohc vtec and engine wire harness, do I still need to wire a knock sensor? I thought that was only for LX and DX models with no vtec? I could be wrong. But again thanks for the tips and helping me out.
Old Jun 18, 2004 | 06:59 AM
Sam1am26's Avatar
yeah, your harness already has vtec and a knock sensor wired in so you're good to go...
Old Jun 24, 2004 | 01:31 AM
vroomvroomcivic's Avatar
so since he has the sohc vtec motor and harness, what wires does he have to add for the h22a?
Old Jun 24, 2004 | 06:56 AM
H23 Power's Avatar
Default Re: (vroomvroomcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomvroomcivic &raquo;</TD></TR><TR><TD CLASS="quote">so since he has the sohc vtec motor and harness, what wires does he have to add for the h22a? </TD></TR></TABLE>
there shouldn't be any wires to add
Old Jun 24, 2004 | 07:44 AM
Sam1am26's Avatar
Default Re: (H23 Power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23 Power &raquo;</TD></TR><TR><TD CLASS="quote">
there shouldn't be any wires to add</TD></TR></TABLE>
Yeah, you shouldn't have any wires to add, but there will be some wires you will just have to extend...
Old Jun 24, 2004 | 10:48 AM
cool thanx for the response,
also what about the ecu i should use? i have a usdm h22a1 should i use a usdm p13 or jdm? is there a difference? what is reccomended.
Old Aug 5, 2004 | 01:46 AM
AGENT 99's Avatar
bringing this post back from the dead b/c my *** needs to know these answers too!!!
Somebody should do a writeup- How to swap a h22 into a 5th gen accord. PLease?
Old Aug 5, 2004 | 04:37 AM
iakona's Avatar
for the P/S, use a 5th gen top line attached to your accord line to the rack.
Old Aug 7, 2004 | 04:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomvroomcivic &raquo;</TD></TR><TR><TD CLASS="quote">cool thanx for the response,
</TD></TR></TABLE>**** I used a p13 ecu and it ran just fine, just that I FREAKING dont have Vtec....shiiiiit that sucks....something wrong with my sensors, but its all good...But I also used a GSR ecu and it seemed to run a little bit stronger, dont know why but it did?
Old Aug 9, 2004 | 05:05 AM
iakona's Avatar
leaner fuel map. it'll work, but no VTEC there either.
Old Aug 14, 2004 | 12:23 AM
Jago's Avatar
For a 94 accord swap all you need is a 97 prelude power stering braket.
Bolt that to the motor and use the accord pump. This makes it simple and easy.
Old Aug 14, 2004 | 08:17 AM
ichibanjap's Avatar
Default Re: (6gcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6gcivic &raquo;</TD></TR><TR><TD CLASS="quote">bringing this post back from the dead b/c my *** needs to know these answers too!!!
Somebody should do a writeup- How to swap a h22 into a 5th gen accord. PLease?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=797528 Almost all the way at the bottom of the page is a detailed write up. H22a.org, if it's still up, has a good write up too.
1990hondaf22a
Apr 18, 2015 02:28 AM
jlhansen
May 9, 2007 07:47 PM
Libertariat
Aug 18, 2005 07:00 PM
integra pride
May 8, 2004 09:40 PM
