Removing side moldings
Old Jun 16, 2004 | 04:05 AM
Weapon's Avatar
Default Removing side moldings
Anyone know how to or a good method remove the side moldings without snapping the clip behind them?
I saw some thin JDM side moldings for a 2 door integra and wanted it but wasnt really sure on how to remove it
Old Jun 16, 2004 | 04:40 AM
95gsr's Avatar
Default Re: Removing side moldings (Weapon)
remove door panel and sqeeze the clip
Old Jun 16, 2004 | 05:01 AM
Googs16's Avatar
Default Re: Removing side moldings (95gsr)
I used a small pick with a 90 degree bend to push one side of the clip down at a time, you gotta pull the molding slighty away from the car and work one clip at a time, its a little tricky but if you are patient it works just fine. and don't forget to take off the nut on the end where you open the door.
Old Jun 18, 2004 | 11:56 AM
Weapon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsr &raquo;</TD></TR><TR><TD CLASS="quote">remove door panel and sqeeze the clip </TD></TR></TABLE>
How would u take it off the front fender and rear QP then?
Old Jun 18, 2004 | 01:38 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
front fender - remove the wheel well cover enough to access the the clips from the other side of the fender
rear QP - remove the rear interior side panels to access the clips. hope this helps.
ANNiHiLATORS
Sep 7, 2009 02:16 PM
vegas hoe
17
Dec 15, 2006 05:56 AM
91hondacrx
Jun 23, 2006 10:15 PM
MidwestSi
Apr 11, 2005 10:28 AM
DSC
Mar 4, 2002 08:34 AM
