Please guys take a look at this
Old Jun 16, 2004 | 12:05 AM
gtowni3's Avatar
Default Please guys take a look at this
my ek used to be an automatic the mechanic said....and i now have a broken motor mount...and the previous owner says he has had problems with that same motor mount....does this mean it will keep breaking?....even if i use aftermarket mounts??
Old Jun 16, 2004 | 12:16 AM
TheNasty0ne's Avatar
Default Re: Please guys take a look at this (gtowni3)
No. Unless it is installed wrong or the bushing just gone wrong.
Old Jun 16, 2004 | 04:08 AM
inline4's Avatar
You might want to do a search for automatic to manual conversion on EK's.
I know that with EG's if you switch the tranny from automatic to manual that you will either need to reweld one of the tranny mounts into a different position, or buy a new custom mount from hasport or one of those companies and you don't have to go through the hassle of cutting and rewelding.
Old Jun 16, 2004 | 04:24 AM
96 SOHC VTEC's Avatar
I broke a motor mount and got a new one, no problems. If you are really worried about it then get some motor mount inserts when you get your new motor mount.
Old Jun 16, 2004 | 06:22 AM
Animal's Avatar
Auto to Manual swap requires cutting the old tranny mount off and replaceing it will the 5 spd one. It is at a flatter angle to mount the tranny. If it keeps breaking then someone has installed something wrong or they can weld.
92 CIVIC 4DR
Jan 29, 2008 01:50 PM
jdmcoop
Aug 6, 2006 09:35 AM
Si Integra
Mar 9, 2005 12:38 PM
kin6david
Jan 13, 2004 12:10 AM
