can someone help me ID this?
Old Jun 15, 2004 | 11:02 PM
b20izzle's Avatar
Default can someone help me ID this?
the cylinder thingy, it came off a 97 gsr head i was putting together the head and this was laying around. thanks
Old Jun 16, 2004 | 05:14 AM
acy76's Avatar
Default Re: can someone help me ID this? (b20izzle)
It looks like a dowel pin. If that is a valve cover nut next to it, it's probably one of the small dowels on the cam caps or the bridges above. Take the caps off and find out which one is missing.
Old Jun 16, 2004 | 07:10 AM
mmuller's Avatar
Mad Scientist
valve cover nut and vtec rocker piston
is the little dowel looking thing hollow in the middle?
Old Jun 16, 2004 | 10:22 AM
SprayinCX's Avatar
Default Re: can someone help me ID this? (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">It looks like a dowel pin. If that is a valve cover nut next to it, it's probably one of the small dowels on the cam caps or the bridges above. Take the caps off and find out which one is missing.</TD></TR></TABLE>
it would be the one under #3 cam cap.
or bepending on size it could be the one that lines the head up?
Old Jun 16, 2004 | 10:25 AM
Joseph Davis's Avatar
Default Re: can someone help me ID this? (SprayinCX)
I can't see how thick the dowel is... might be one of the ones in the plastic timing belt cover, got mixed in with your head stuff.
Old Jun 16, 2004 | 10:32 AM
b20izzle's Avatar
WOW thanks for all the replies...yes it is hollow but it is not that big it is fairly small not as big as the dowl pin to align the head. i am a noob at all this and appreciate all this help!!
Old Jun 16, 2004 | 10:42 AM
976's Avatar
976
New User
Default Re: can someone help me ID this? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">valve cover nut and vtec rocker piston
is the little dowel looking thing hollow in the middle?</TD></TR></TABLE>
Yeah...
Old Jun 16, 2004 | 02:21 PM
mattssi's Avatar
yeah it goes under the no 3 cam holder! once you take it off, you can miss where it goes!
Old Jun 16, 2004 | 05:30 PM
b20izzle's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">yeah it goes under the no 3 cam holder! once you take it off, you can miss where it goes! </TD></TR></TABLE>
does it go here?
Old Jun 16, 2004 | 09:30 PM
ScottEK's Avatar
Default Re: (b20izzle)
Yeah there should be that and an O ring that fits around it I believe.
Old Jun 16, 2004 | 11:39 PM
b20izzle's Avatar
Default Re: (beta13)
THANK YOU EVERYONE FOR HELPING ME OUT!!!! TO H-T..i will post pictures up of my b20vtec wen im done!!
KMk51188
Dec 16, 2006 02:19 PM
cleanej2
Nov 24, 2006 09:35 PM
96b18c
Jan 4, 2004 05:02 PM
speedyonez
Nov 28, 2003 04:38 PM
