Easy Fuel Pump Wiring Question
Old Jun 15, 2004 | 10:48 PM
MrIllegalX's Avatar
Default Easy Fuel Pump Wiring Question
(searching is overrated)
Are the fuel pump wires the same for 92-95 civics and 96-98 civics? I'm installin a fuel kill switch, and the install guide I'm usin is for a 94 civic. I'm just wonderin if the wire colors are the same....
Old Jun 15, 2004 | 11:17 PM
MrIllegalX's Avatar
or does anyone know what color does what?
For the 94 it says the yellow wire with a green stripe running to the front is POWER and the same wire running to the pump is the LOAD. (or is it a different wire?)
is it the same?
Old Jun 16, 2004 | 04:20 AM
MrIllegalX's Avatar
i think i got it, all i need to know is it still the yellow wire with the green stripe that I need to cut?? come on, I know some one has done this on their 96-98 civic.
Old Jun 16, 2004 | 05:29 AM
Deemeetree's Avatar
Electrician
Yes, it's the YELLOW/GREEN wire that goes to the fuel pump. Splice this, solder the wiring, run the switch, off you go.
boostedefhatch
May 4, 2010 03:00 PM
99ssinoc
Jul 2, 2007 05:44 AM
nboost
Dec 1, 2006 09:39 AM
boosted k20
Aug 16, 2004 07:58 PM
Mazmay
Aug 16, 2002 12:34 PM
