Test your swap knowledge, major mind bender...
Old Jun 15, 2004 | 10:45 PM
Rene M's Avatar
Default Test your swap knowledge, major mind bender...
Ok this one has me, I need some help with this weird one...
Ok, a friend drives over to our shop in his zc powered CRX and wants to try out a different ecu on his car because he is running a 89 teg ecu. So while i am standing there he disconnects the teg ecu and tries out an 88 teg ecu to see if it is good or not. The car does not start and has no fire. So he removes the 88 ( figures its bad )and plugs in his 89 teg ecu. Now the red light is on and the Check engine light both stay on. According to the service book the ecu is dead and should be replaced?? We then try two different ecu's from cars that run and the car still has no fire? It drove in?? What just happened? Any one??? One ecu is now bad ( the one he drove in on) and none of the other will start the car???
Old Jun 15, 2004 | 10:47 PM
ImportHatch's Avatar
Default Re: Test your swap knowledge, major mind bender... (Rene M)
does the original ecu that is now "bad" not start the other cars either?
Yager-
Old Jun 15, 2004 | 10:53 PM
Rene M's Avatar
Default Re: Test your swap knowledge, major mind bender... (ImportHatch)
Out of fear we did not try that... Why what are your thoughts?
Old Jun 15, 2004 | 10:56 PM
brentmc79's Avatar
Sounds like a main relay problem to me...
Old Jun 15, 2004 | 10:59 PM
90civichbsi's Avatar
Default Re: (brentmc79)
may wanna check the plugs for corrosion... that can do it too
Old Jun 15, 2004 | 11:01 PM
Rene M's Avatar
What makes you say that? We still have fuel pressure but only when the key is in crank mode. If you turn the key on it will not prime for some reason?
Old Jun 16, 2004 | 04:46 AM
Jared's Avatar
Default Re: (Rene M)
sounds like the ecu is not getting a proper ground or power at some input.
Old Jun 16, 2004 | 10:05 AM
Rene M's Avatar
Default Re: (Jared)
I will give it a try... Thank you all for your time..
Old Jun 16, 2004 | 10:41 AM
racerxb18b's Avatar
you blew your ecu fuse under the hood change that it'll be fine
Old Jun 16, 2004 | 11:09 AM
91civicEX's Avatar
Default Re: (racerxb18b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxb18b &raquo;</TD></TR><TR><TD CLASS="quote"> you blew your ecu fuse under the hood change that it'll be fine</TD></TR></TABLE>
same thing happened to me. go through your underhood fuses. i think it was a 15 amp fuse.
Old Jun 16, 2004 | 11:17 AM
hahagasdcrx's Avatar
replace the ecu and the hazard fuse under the hood, that may be all it is....
Old Jun 16, 2004 | 12:49 PM
Rene M's Avatar
Default Re: (hahagasdcrx)
I will try it.. Thank you all..... You guys rock..
Old Jun 26, 2004 | 11:19 PM
Slow_Em1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">I will try it.. Thank you all..... You guys rock.. </TD></TR></TABLE>
yes we do
Old Jun 27, 2004 | 03:20 AM
Fobtions's Avatar
Default Re: (Slow_Em1)
first of all that 88 teg ecu must be bad or the guy didnt insert the plugs in correctly and probably shorted out some pins or some hobo wiring might be the case. thus blowing at least one fuse.
it would be wise to find why it blew a fuse , before doing anymore damage.
Old Jun 27, 2004 | 03:31 AM
Dibble's Avatar
Same thing happen to me, it was a fuse.
Old Jun 27, 2004 | 06:05 AM
AychTwenee2's Avatar
there should be a fuse for the fuel pump too. If it is not priming on accessory, then you might check that, my brothers car did that same ****! Amazing how a little *** fuse will ruin your day
Old Jun 27, 2004 | 07:04 AM
B16A1-EF9's Avatar
Default Re: (VeeTekCrx)
After checking the fuses, check the plugs that go to the computer. Chances are they are loose, maybe corroded.
I would also say check everything out and find out why this happened before you go any further with other ecus. Keep in mind that these - our cars do have a history for main relay problems also.
Canadian_EF
Sep 5, 2009 12:58 AM
driftam1
Oct 27, 2008 02:43 PM
Red_Si
Jul 11, 2002 07:34 AM
USDM 4G VTEC
May 13, 2002 06:00 AM
civic2299
May 11, 2002 11:31 PM
