::::Anyone Know how to remove tint?:::::: plz help!
Hey me and my friend wanna remove the tint off his ep3.....but we don't know how....a lot of people say "use a razorblade and windex" but are there any other suggestions out There....i tried searching but it talked about sum cheap tint!! plz help!!!!
there was a thread bout this. try searching more
i think what poeple said is spray with windex, cover with black trashbag, let it sit in sun for x minutes, take off trashbag, use a blade to scrape off tint.
I just sliced the film with a razor blade and started peeling. I used goo gone to get the adhesive gunk off afterwards. Be warned, the tint smells gross.
Here are a couple that I found just by searching the word "tint."
https://honda-tech.com/zerothread?id=882473
https://honda-tech.com/zerothread?id=836953
Good luck. I just used 409 and a razorblade. I would get a few razorblades because it helps if they are sharp. Be sure not to dig into the window so you don't have scratches all over it. By the way, lay some cotton towels on your dash, etc so you don't mess them up. When you have the tint off don't try wiping away the glue with a towel, it doesn't work that well. I just sprayed the 409 directly on the window and scraped the glue off with the razorblade. Don't forget some dish gloves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justagsr »</TD></TR><TR><TD CLASS="quote">Here are a couple that I found just by searching the word "tint."
thanx a lot
</TD></TR></TABLE>thanx a lot
This sounds like it will work http://www.tintdude.com/remove.html
But i will probably do a write up...on this and let u guys know how it goes!!!!
took the tint off used a razorblade and sum simple green....lemon scented....yumm...but there sum adhevise still on there and i think it might be off in a couple washes...but do u guys have any suggestions???
Well ...to remove the tint we used simple green and razorblade .....
first make a cut on the other most park of the window.....becareful do not cut the glass!!! this takes time!! After u have a fold begin tear it downward...try to tear in it in huge chucks so u don't have to use the razor blade that often....when pullin the tint down spray sum simple green on the part of window that does not have the tint anymore this helps remove the tint easier and faster!!! after the tint is off u gonna have spray simple green like a mad man!!! now u gotta remove the adhesive .......then just start cleaning........i noticed sum streaks...when i was done so i sprayed sum
to help us out....this is the whole process pretty simple just take ur time.....
oh yeah simple green works great on cleaning engines!!!
to help us out....this is the whole process pretty simple just take ur time..... oh yeah simple green works great on cleaning engines!!!
