what bar did I get?
Old Jun 15, 2004 | 09:03 PM
silver_nteg's Avatar
Default what bar did I get?
hey all,
Just bought this bar thinking it was the rear sway bar, but its not. What is it and what does it do??
http://www.acuraautomotivepart...y.jsp
(Its number 3)
Old Jun 15, 2004 | 09:11 PM
96dc2's Avatar
Default Re: what bar did I get? (silver_nteg)
Link doesn't work. Just post the image.
Old Jun 16, 2004 | 09:57 AM
Default Re: what bar did I get? (96dc2)
Its the small middle bar
Old Jun 16, 2004 | 10:04 AM
One Bad GeeSeeR's Avatar
that looks like a stock itr rear tie bar. dont think that will work for non itr integras
Carlo
Old Jun 16, 2004 | 10:31 AM
ferio 95's Avatar
Default Re: what bar did I get? (One Bad GeeSeeR)
it shold have a bolt in the holes where it will go. If not it will have spot welds which will clearly show where to drill the holes for it
Old Jun 16, 2004 | 10:33 AM
Default Re: what bar did I get? (ferio 95)
so does it really do anything and also will it fit? I thought it was the rear sway bar
Old Jun 16, 2004 | 10:37 AM
eg6sir-s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver_nteg &raquo;</TD></TR><TR><TD CLASS="quote">so does it really do anything and also will it fit? I thought it was the rear sway bar </TD></TR></TABLE>
that bar is not a sway bar...that bar will only work on type-r chassis. it goes on your rear lower cross member between where the lower control arms bolt on too.
96dc2's Avatar
Won't fit as mentioned before because your rear subframe is different from ITR.
Old Jun 16, 2004 | 08:22 PM
GrafxDesignGuy's Avatar
these are sway bars
if you are looking to stiffen up your cornering the sway bars will help you more, so if you cant get that ITR tie bar to work on your car, i'd return that and get this. Although you'll prolly want to get a tie bar later on.
Old Jun 16, 2004 | 08:46 PM
hollis's Avatar
Default Re: what bar did I get? (GrafxDesignGuy)
trunk brace maybe?
Old Jun 16, 2004 | 09:02 PM
smurfey002's Avatar
that is what i was thinking, but i didnt know if they sold that or not, but i think it'd be #4 if anything
Old Jun 16, 2004 | 09:15 PM
Curtisbeef's Avatar
You bought a lower Tie Bar im 100% sure
you buy the sway bar by going to the "REAR LOWER ARM " section and its # 5 on that page
Old Jun 16, 2004 | 09:52 PM
SilverDc2's Avatar
Default Re: (Curtisbeef)
it ain't gonna work.....unless you weld a custom support on your frame...
Old Jun 16, 2004 | 09:58 PM
timmy8151's Avatar
Default Re: (SilverDc2)
If you want to do the ITR rear sway upgrade go to http://www.geocities.com/bretq to get all the info you need.
The ITR rear sway is called a "Spring" by Acura
005 52300-ST7-Z01 SPRING, RR. (22MM) $63.15
Old Jun 16, 2004 | 10:10 PM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
its a rear trunk bar.. if u r not itr.. u need to drill holes..
Old Jun 17, 2004 | 01:03 AM
96dc2's Avatar
Default Re: (SpoodgeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoodgeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">its a rear trunk bar.. if u r not itr.. u need to drill holes.. </TD></TR></TABLE>
It's a lower tie bar. #4 is the trunk bar.
Old Jun 17, 2004 | 01:12 AM
JFG Kevin's Avatar
Default Re: (96dc2)
yes...i'm 100% sure also that you bought a lower tie bar...nothing else will go there but that
Old Jun 17, 2004 | 09:25 PM
Don't know if its the tie bar... look at the way the bar is laid out in the photo, everything else is relative to the way it would lay in the car. Strut tower bar is shown as it would be installed and the trunk bar is shown on its side, as it would be installed on the car... the bar in the middle is shown as if the bolts would go up and down. If im not mistaken a tie bar is installed is installed where the LCA connents to the frame.. making the bolts go back to front.
strut bar.
i think its the other trunk bar that sits across the spare tire well...
Old Jun 17, 2004 | 09:31 PM
grafxdesignguy, do you have an R? if not how did u install that "spare tire bar"?
Old Jun 17, 2004 | 09:37 PM
Dont have a Type R... found that pic on H-T... thats not a real ITR bar. its DIY bar someone made and took a picture of.. forgot what the thread was but you should be able to search for it.
if you take the carpet out of your trunk you should see some circles that need to be drilled out where the bars go... i think they are on the non TR models too. not sure.. didnt bother to look at my car.
take a pic when its installed i would like to too a real one... let us know if it made a difference in your handling.
Old Jun 17, 2004 | 10:48 PM
salvatore's Avatar
yeah do it...i would like to hear whether any of these bars help....i mean the trunk bar and DIY bar
Old Jun 17, 2004 | 11:36 PM
Quiks66's Avatar
Default Re: what bar did I get? (salvatore)
My friend and I made a "rear trunk" bar out of some scrap steel similar to the one pictured. To my surprise it actually made a very noticeable difference. Worth the $5 we threw down for sure
Old Jun 17, 2004 | 11:41 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrafxDesignGuy &raquo;</TD></TR><TR><TD CLASS="quote">strut bar.
That's NOT a strut bar. That is a lower tie bar. Once again #3 is a tie bar, and #4 is a rear trunk bar. That is how it mounts, STOCK.
Here is the rear underside of an ITR.
Here is the ITR trunk brace in an ITR.
Modified by 96dc2 at 12:53 AM 6/18/2004
Old Jun 18, 2004 | 03:05 AM
IntEGNYC's Avatar
oopsies!
Old Jun 18, 2004 | 08:58 AM
96dc2, you seem to know the most about this topic, is it worth me trying to install that lower tie bar?? also the guy has the trunk brace he was gonna sell to me, but it was 50 bucks (which I dont think is worth it). From the pic you posted of the ITRF underside, it seems all I have to do is mount that rear tie bar into the ends of the lower control arms???
