vafc install help
Old Jun 15, 2004 | 08:11 PM
hatchback_al's Avatar
Default vafc install help
ok i have two questions on the vafc installation into my 91 civic dx with obd0 ecu. 1. where does the VTM wire connect to, i know u can see it on the updated apexi site but that is all for obd1 and obd2 ecus. 2. there are 2 ground wires from the vafc that connect to the ecu harness on the same wire, is this right?
Old Jun 15, 2004 | 08:20 PM
slowpokesi's Avatar
Default Re: vafc install help (hatchback_al)
u dont use the vtm wire
yes there are 2 wires that you hook up to the same wire, however one wire needs to be connected closer to the ecu than the other ground, problem is i dont remember wich one but the manual should be very specific about wich wire.
Old Jun 15, 2004 | 08:43 PM
crxgator's Avatar
Default Re: vafc install help (slowpokesi)
brown closer to ecu...
also apexi shows the install for obd0
http://apexi-usa.com/productdo...c.pdf
page 17 top left corner(H1-a) of the wiring diagram is for the obd0 ecu...
Old Jun 15, 2004 | 08:48 PM
Default Re: vafc install help (crxgator)
the vtm signal is for the vtec oil pressure i believe and apexi says it should now be installed, so do quite a few other people
Drizzo
Nov 26, 2005 09:35 AM
4gzchatch
Sep 15, 2004 06:41 AM
SoldMyEM1
Apr 5, 2004 03:22 PM
Accord_Munch
Dec 5, 2002 06:36 AM
PhatOptimo
Oct 31, 2002 02:33 PM
