replacing ball joints?
Old Jun 15, 2004 | 07:13 PM
zcrxt's Avatar
Default replacing ball joints?
Alright first of all i have searched and couldnt find anything, second my ball joint stripped out so i must replace. I bought new joints at autozone and i also rented the ball joint press. I tried for a few hours to use it but i can not get it out? Has any one replaced their ball joints before and/or used this took before.
Thanks for the help
Ben
P.s. This is the tool--- http://www.autozone.com/servle...s.jsp
Old Jun 15, 2004 | 09:02 PM
eda6's Avatar
Default Re: replacing ball joints? (89zchf)
it's been a while since I did this.
Take the steering knuckle and put it in a vise.
We used that tool. The one we used was like 12" long. It was a big momma one.
That autozone one looks like crap.
One person was holding the knuckle and the other was working the tool.
We pushed the ball joins out, flipped the tool around and pushed back in.
Basically it was a bitch.
Take the knuckes to a suspension shop and let them do it.
it's worth the money IMO.
Although it can be done at home it's a pida.
Checked
Old Jun 16, 2004 | 12:29 AM
7PSI CRX's Avatar
Default Re: replacing ball joints? (eda6 hb)
Where are you stuck?
Getting the Tapered part out of the lower arm, or getting the complete ball joint out of the knuckle?
For the tapered part...
What you really want to use is something like this
(Appropiately sized, of course)
And since you're never going to use them again anyway, this will do also.
As far a pushing the whole thing out of the knuckle....
A large deep socket and a big *** hammer.
Old Jun 16, 2004 | 01:49 AM
DC 2's Avatar
Default Re: replacing ball joints? (7PSI CRX)
I replaced mine after 150k, took the snap ring out, put the castle nut back on, then beat the living **** out of it. Its all about a good hit. Was fairly easy.
Jack it up really high so you can have a lot of leverage.
Old Jun 16, 2004 | 03:39 AM
1st-hybrid's Avatar
Default Re: replacing ball joints? (EH3B18B)
This is basically what I did, but I had the knuckle out of the car. It was very easy to do, then I tapped the new ones in, no sweat.
Just don't forget to take out the snap ring
Old Jun 16, 2004 | 04:30 AM
kylefakesi-r's Avatar
Default Re: replacing ball joints? (1st-hybrid)
knuckle out, in a vise.
air hammer that ****-send it accross teh shop.
reinstall with air hammer and a impact socket that is about the same diameter as the ball joint.
5 minute job for the capable and if you have tools.
Old Jun 16, 2004 | 05:07 AM
senpai's Avatar
Return that piece of **** ball joint press tool. This is all you need, my friend.
Old Jun 16, 2004 | 05:35 AM
RACINTWEEK's Avatar
Default Re: replacing ball joints? (maztur)
make sure that the new snap rings fit right if they dont then your gonna have problems i got ball joint fro, 3 diff manufacturers and none of them fit right i had to go to honda to get the rings
Old Jun 16, 2004 | 08:22 AM
AgentJam's Avatar
Default Re: replacing ball joints? (RACINTWEEK)
my new honda ball joints didn't have snap rings...or a place to put them if you wanted to...
Old Jun 16, 2004 | 02:32 PM
zcrxt's Avatar
Default Re: replacing ball joints? (AgentJam)
Thanks guys for the help again. I got it replaced and now its back on the road. Thanks again for all of the quick help.
Ben
WhiteOnRice
Aug 18, 2024 11:11 AM
dpkelly
16
Dec 29, 2023 07:19 AM
efeher
11
Aug 2, 2011 07:05 PM
PatrickGSR94
Suspension & Brakes
18
May 12, 2010 09:55 AM
MugenHonda
27
Jan 26, 2005 07:54 AM
