dpfi wiring question....I need some serious help
Old Jun 15, 2004 | 06:00 PM
Acuraman918's Avatar
Default dpfi wiring question....I need some serious help
I have a mutt of a setup. I have a D15b2 90' crx hf motor, I have a stock wiring harness from a 91' civic std, and to bring the two together I bought a injector harness will all the plugs and resistor box from a 89 teg. From what I can see the dizzy plugs are different. Basically I need to know how to bring it all together. Please help me.
Old Jun 15, 2004 | 06:13 PM
Redline130's Avatar
Default Re: dpfi wiring question....I need some serious help (Acuraman918)
First off, do you have a D15B2 (DX DPFI motor) or a D15B6 (HF MPFI motor)? What trim is the car that you are dropping the motor into? DX, Si ?
Old Jun 15, 2004 | 07:40 PM
civickiller's Avatar
Default Re: dpfi wiring question....I need some serious help (Redline130)
yeah is your car dpfi or mpfi, because hte std hareness is a dpfi, but the crx hf comes mpfi
Old Jun 16, 2004 | 01:02 PM
I am dropping a mpfi hf motor into a std hatch with dpfi.
Old Jun 16, 2004 | 08:21 PM
Redline130's Avatar
Your easiest option is to convert your existing DPFI harness to MPFI. You will need an injector resistor, and the injector clips off any OBD0 MPFI harness. If you can, you should get the distributor plug as well off the MPFI harness. Don't try to swap out the entire harness, just add the necessary wires that you will need. IM civickiller, I'm sure he can help you out with the wiring.
Old Jun 19, 2004 | 01:26 AM
nikitad's Avatar
Yeah, 89 teg harness will have everythign you need but the distributor plug.
you can steel that plug for n an 86-89 legend (o firewall, not on distro) or some other car.
fenix4o9
Jun 23, 2007 01:06 PM
dividebyzero
15
Jan 4, 2004 07:16 AM
Mr. UnderHill
Nov 26, 2003 09:18 AM
DOHC_EF
Oct 12, 2003 05:56 PM
spettinger
Mar 25, 2003 09:32 AM
