Engine Smoking 91 Accord
Old Jun 15, 2004 | 04:21 PM
mullenex's Avatar
Default Engine Smoking 91 Accord
I have a problem with a 91 accord 2.2 smoking when started cold and last about 15 minutes. I pulled the motor to figure if it was the head or rings.
The #2 piston is very clean valves on the exhaust side of #2 is got a milky look on them. Like water and oil mix. same one the plug of #2. Cylinder wall still has cross hatchings and looks fine.
Anyone have an idea of whether I should be looking at rings or Valve seats.
I can take pictures if that would help also.
Thanks
Don
Old Jun 15, 2004 | 05:36 PM
jwogen1's Avatar
Default Re: Engine Smoking 91 Accord (mullenex)
is it burning off quite a bit of oil--obviously from the smoke it is burning some, but......
Old Jun 15, 2004 | 05:38 PM
mullenex's Avatar
Default Re: Engine Smoking 91 Accord (jwogen1)
It will burn a quart a week running normal about 1 tank of gas.
Running it hard will burn a quart in 150 miles.
Thanks for the help
Don
Old Jun 15, 2004 | 05:45 PM
jwogen1's Avatar
hmmm--not much help without actually seeing it
Old Jun 15, 2004 | 06:23 PM
mullenex's Avatar
Here is a couple of pictures
Hope this will help
Don
Old Jun 15, 2004 | 06:36 PM
jwogen1's Avatar
was there oil running down the block?
Old Jun 15, 2004 | 06:45 PM
mullenex's Avatar
Check the block and the front is very clean. Back has some oil on it but not alot. Some more history on it.
There was a couple of valves and seats replace about 20,000 miles ago. Not long after it started smoking. The engine has 193,000 on it but still ran very good.
I ask the owner that had the valve work done if they knew which cylinder but they can't remember. I have a good feeling it was the #2
Thanks again for the help
Don
Old Jun 15, 2004 | 07:02 PM
jwogen1's Avatar
i bent the 1st and 3rd valves in my old civic, and after the new valve work she went through oil much quicker.....and i would have to agree with your thoughts on #2 from the pics. By the way welcome to H-T
Old Jun 15, 2004 | 07:15 PM
mullenex's Avatar
Thanks for the Welcome and Thanks for the extra help and info. I will plan to pull the #2 piston tomorrow and see if there is a ring stuck. I will let you know what I find. Maybe this can be an easy fix or maybe I will look for a V-tech to put in it.
Thanks again
Don
Old Jun 15, 2004 | 07:30 PM
weezo182's Avatar
gees #2 looks like crap... best of luck.....
Old Jun 15, 2004 | 07:55 PM
alb_accord's Avatar
1 2 and 4 look bad. when i took my engine out the piston where the valve proke loked like #1 2 and 4. the other 3 looked like ur #3.
since u there replace the piston rings. do a fix the head and u good to go for another 200k
Old Jun 16, 2004 | 06:45 PM
mullenex's Avatar
Default Re: (alb_accord)
Well I just took the pistons out and the number 2 just fell out when I removed the cap. The other 3 had to be pushed out. No rings was broken but maybe a little stuck on the oil ring. I plan to mik it tomorrow and see if the cylinder walls are all the same. Hopefully I can just replace rings and bearings and have head reworked and be back in business.
Old Jun 16, 2004 | 08:06 PM
alb_accord's Avatar
rebuild it for force introduction. make the engine ready for turbo. lol. u never know u might wanna put a turbo there. lol good luck with the work. show some pic of u work man.
jmac75
Oct 23, 2012 12:11 PM
pswann
Aug 13, 2009 02:42 AM
Xx91AccordxX
Apr 4, 2006 01:52 PM
pu3rt0r1c0
Dec 11, 2004 07:27 AM
honda3
Sep 24, 2004 11:35 AM
