CEL dosnt store?!
hey guys,
A little backround info first. I uninstalled my VAFC the other day, while the VAFC was installed I did NOT receive this issue.
Usually after my car warms up and I drive around for a little while I get this strange CEL. I know this sounds strange but 95% of the time it happens when I am downshifting or slowing down.
The problem is that when I click my key back 2 clicks, throw a jumper in the plug and try to read the code, the code dissapears. After some driving it'll reappear again and I cant find out the CEL#!
First thing I thought was loose wiring on from the VAFC being uninstalled. I only cut 1 wire so I soldered it together well and just taped off all the other wires. Checked all other wiring and its all fine.
What could this be?!
Note: When CEL is on car runs fine, everything engages and works as it does without the cel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">did that to me, it was my secondary o2 sensor, only way i could find out what my code was...was to drive around with the jumper and wait for he cel to turn on, then it flashed accordingly.</TD></TR></TABLE>
That will work eh? I wasnt sure if it would or not. Looks like I'm going to jump it and drive home from work and see if the CEL gives me a code so I can fix this. Its SOOO annoying turning the car off when im at a light then turning it back on and driving for another 5-10 mins before i get the cel again.
