FRIKKEN NOISE. Please help
Old Jun 15, 2004 | 02:08 PM
verbal's Avatar
Default FRIKKEN NOISE. Please help
Hello. I've come to honda-tech as a last resource, hoping maybe you guys can help me. I have a 95 accord ex sedan 5-spd. When i turn right at 10-20 mph i get a metal on metal chainy grinding/scraping noise. It sounds like loose change in your pocket. At first I thought it was coming from my left front wheel (maybe wheel bearing, dust shield, warped rotor problem). I inspected everything, even took it down to my local mechanics. They didn't find ****. So here I am. Also, sometimes with a little bit cooler weather (50-60 degrees F) the noise is less or not apparent at all. Lately the noise has been apparent occasionally when I am accelerating out of a turn for a few seconds in addition to the noise during the turn. Perhaps a steering linkage problem? ... I am close to giving up and just driving it until something breaks or I die. lol. Any help whatsoever would be appreciated. Thanks
Michael
Old Jun 15, 2004 | 03:42 PM
Mike813's Avatar
Default Re: FRIKKEN NOISE. Please help (verbal)
is your car dropped? could be rubbing the fender or splash guard at a turn?
have you checked brakes or warped rotors?
Old Jun 15, 2004 | 03:59 PM
verbal's Avatar
Default Re: FRIKKEN NOISE. Please help (Mike813)
Yeah my accord is dropped with an eibach pro kit. It's a metal sound though, so it wouldn't be a plastic part it's rubbing on right? I'll check it for wear in the fender area. As far as the warped rotors, is there any way to confirm that they are warped? I can spin them when the car is on jack stands and they won't make the noise no matter what the angle of steering. Strange thing. Thanks for your advice.
Michael
Old Jun 15, 2004 | 04:09 PM
.bagged's Avatar
could it be the upper A-arms rubbing teh top of teh wheel well?? check there. and why in gods name were we the last option
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verbal &raquo;</TD></TR><TR><TD CLASS="quote">Hello. I've come to honda-tech as a last resource
Old Jun 15, 2004 | 04:14 PM
verbal's Avatar
Default Re: FRIKKEN NOISE. Please help (bagged93accord)
haha because you guys know more about hondas than local shops here (WI), or any other website i have found. short of going to the honda hq in torrence cal, you guys know hondas really well. I doubt it'd be the arms because the car has 138k on it and how would a noise just appear from the arms? I'll check them though. Thanks
Old Jun 15, 2004 | 04:16 PM
.bagged's Avatar
no no.. when you lower it you can reduce clearance in the wheel well. the a-arm is notorious for rubbing the inner fender well or even pounding it
Old Jun 15, 2004 | 04:17 PM
verbal's Avatar
it's been lowered for 50k ... think it could still do it?
Old Jun 15, 2004 | 04:19 PM
.bagged's Avatar
nope. did you just get a camber kit or anything?
Old Jun 15, 2004 | 04:20 PM
verbal's Avatar
nothing.
Old Jun 15, 2004 | 05:30 PM
jwogen1's Avatar
re-check and see if maybe the dust shield is rubbing on the inside of the rotor. when it happened to mine it was a continuous noise--so maybe not in your case....
Old Jun 17, 2004 | 05:06 PM
verbal's Avatar
Default Re: FRIKKEN NOISE. Please help (jwogen1)
Will i see wear on the inside of the rotor? What exactly am i looking for? I eat dust shields.
Old Jun 28, 2004 | 11:39 PM
verbal's Avatar
Hey guys just wanted to update this thread. I still have the noise and it's gotten worse. It happens now when im braking as well... fucked up. So i'm ordering 4 new brembo blanks and axxis mm pads. And I'll bend the **** out of the dust shield on my front left wheel. If this doesn't work my old high school is pretty tall and I think I can die from falling off of it at the right angle.
Old Jun 29, 2004 | 12:02 AM
screed's Avatar
are you absolutely certain that the sound is coming from the front of your car?
if not, the ex model accords do come with sway bars and from personal experience, coming out of turns the exhaust sometimes will hit the sway bar and make a metal-on-metal sound. if you have an aftermartket exhaust it makes this possibility even greater.
hope this helps.
Old Jun 29, 2004 | 08:58 AM
H2290's Avatar
Default Re: FRIKKEN NOISE. Please help (screed)
Are you sure this sound is coming from the wheel area? Maybe you just have a cat heat shield or alternator heat shield or header heat shield doing a little rattle job.
Take a little metal pipe or something and go whack any thin piece of metal under your hood/car. Lightly of course. Just go around tapping and see if anything sounds loose.
Old Jun 29, 2004 | 09:13 AM
steve-o40's Avatar
Default Re: FRIKKEN NOISE. Please help (H2290)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure this sound is coming from the wheel area? Maybe you just have a cat heat shield or alternator heat shield or header heat shield doing a little rattle job.
Take a little metal pipe or something and go whack any thin piece of metal under your hood/car. Lightly of course. Just go around tapping and see if anything sounds loose.</TD></TR></TABLE>
i second that
Old Jun 30, 2004 | 06:21 AM
accord2k2's Avatar
check rotor backing plate? might be bent
Old Jun 30, 2004 | 06:43 AM
Viper915's Avatar
Gotta love the "just hit stuff" approach
Old Jul 3, 2004 | 12:07 PM
verbal's Avatar
Default Re: FRIKKEN NOISE. Please help (Viper915)
Hah I like the tap **** idea. If the new rotors (which i needed anyway) don't fix it I'll try that method. I figured that now the noise is when im braking that it wouldn't narrowed the problem to the brakes... I'm probably wrong but oh well. I'll tap some shields if the rotors don't fix it. Thanks a lot guys.
Old Jul 3, 2004 | 12:11 PM
verbal's Avatar
*would narrow the problem
Old Jul 3, 2004 | 05:16 PM
H2290's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Viper915 &raquo;</TD></TR><TR><TD CLASS="quote">
Gotta love the "just hit stuff" approach </TD></TR></TABLE>
Yes Sir, mechanic test on a budget.
Anyway, did you find out what it was yet?
Forrest04
Honda CR-V & Element
Apr 16, 2014 11:50 AM
D7_62
11
Dec 12, 2010 07:22 PM
k20eklipse
Aug 3, 2010 08:40 PM
_RedRiceR_
Jun 19, 2006 12:59 AM
